joddle
- Jan 12, 2007
- Age
- 74
- 2x Pace 2600 C1 (in a box just in case) , 3 x Humax HD Foxstat (2 of which in store as spares) . 3x Manhatten Plaza - Pasat 2.4 PF dish mounted on flat roof with Invacom C120 quad LNB .
- Massanassa, Valencia, Spain
I assume you mean "Invacom" for the LNB - which actually should be about as good as its possible to get - but they don't like long leads so if the cable runs are big that could be part of your problem! Next issue is the feed-horn - are you using the correct one for that dish? I know many people like the Invacom adjustable version although I don't use on myself - but you can't use any old one - it has to be properly matched for the dish. The feed-horn is critical as it is responsible for ensuring the whole dish gets illuminated by the LNB. I have seen people use a so called "universal" Invacom on a PF dish and wonder why results were bad! - I trust your installer has used the correct PF kit! The final adjustments are the focus and skew also absolutely critical in Spain - a fraction of a degree making all the difference.
