Astra 2E: Scandinavia & Baltics Reports
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
You can check
My location for the map (see post 94) Vaasa, Finland
Lat 63.1
Lon 21.6
2E EuroBeam You can check with fta channel "Pick" (Ireland ,11915H !!) .
nb! "Pick" (UK, 12207) is in 2A South.
clubsms
Canaldigital CDC-7000 st
Finland
Yes, I am definatly recieving Pick on 11915 H with 85 cm in Vaasa. Tv gives 66% strength (not reliable).
Old canal digital CDC-7000 combo box gives 36% strengt 45% quality and it is raining and very cloudy here at the moment. Signal is about the same as the astra 2a south beams. Signal start to breakup when strengt and quality is 24-25% with combo box. Using Smart titanium quad lnb.
Did a scan on my tv.
found 499
Tv 410
Radio 48
Data 41
It is raing at the moment and thick clouds in the sky.
t.m
Stockholm
1.2 metre dish
Amstrad dx90 sky+ h.d box
stockholm
Only 5hd left working of bbc,itv ch4 and ch 5 here in Stockholm. Any tips on getting some of them back ?
Retired human
Only 1 way... a larger dish. Unless there's a side-lobe over Stockholm like there was in 2D days...
t.m
Stockholm
1.2 metre dish
stockholm
Yes i know. Thought maybe could get to something by adding a channel or two somewhere. Just to wait and see how things settle down i guess. even when they moved over from 2d i could still get most Everything without a problem
clubsms
Finland
Subscription from sky and you will get Itv 2,3,4 hd and channel 5 hd.
Ch4 irish version is available with Sky FTV card you can find on uk ebay for 5-25 pounds.
With FTV card you will also get Sony Enterteinment TV, Watch, 4 music, Liverpool tv and if you can recieve Astra 2F eurobe beam you will get Sony movies and Motors tv. You will also get some +1 versions.
t.m
Stockholm
1.2 metre dish
stockholm
I have a subscription fro sky inc sports movies and 3D
clubsms
Finland
If you have sky reciever You probably need to add those channels manually. Find the Frequencys at kingofsat. Those FTV channels are all on european or north beam. You will need the right channel version before they open on FTV card.
Example. Itv 2,3,4 HD are on
Astra 2E11758.00H 29500.
Irish channel4 is on:
Astra 2A12480.00V 27500
Watch FTV version is on:
11992 h 27500
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
Estonia, 11473V 29500 channels film4 hd,syfy hd ... very weak signal
t.m
Stockholm
1.2 metre dish
stockholm
The channels i am missing have been moved to a new satellite which is called 2A. The footprint for that satellite is very tight over the u,k. that is the problem.those channels are no longer on the noth beam as far as i am aware. or ?
t.m
Stockholm
1.2 metre dish
stockholm
I am receiving itv 2,3 and 4 and the irish ch4. It is itv1 itv+1 and all bbc channels that are missing
t.m
Stockholm
1.2 metre dish
stockholm
any help would be greatly appreciated
t.m
Stockholm
1.2 metre dish
stockholm
Thanks clubsms I am using that now ! problem is the quality on a 55 inch t.v. am toying with the idea of paying for it to get a better quality picture
clubsms
Finland
Hint: Ad ""adblock"" to your chrome browser.
hXXps://chrome.google.com/webstore/detail/adblock/gighmmpiobklfepjocnamgkkbiglidom?hl=sv
t.m
Stockholm
1.2 metre dish
stockholm
Thankyou Clubsms
You are out of luck with those - they are only available on the uk beams
t.m
Stockholm
1.2 metre dish
stockholm
Thankyou Analoguesat ! As knowledgeable as always
