Astra 2E: Transit to 28.2E
astra 2e 34.4 e
tonight
good morning to all
astra 2e 34.1 e
M60
Northern England
Sub 34E now, this time next week she should have arrived at 28E!
will be that end of next weekend
after that start switich tp
M60
Northern England
No, won't be then, the following week early one morning at the earliest for the beginning of the migrations and suspect it will happen for different services over the course of a few nights.
2D -> 1N migration was on Monday night/Tuesday morning. All channels except BBC on 18/02/2012, and BBC on 25/02/2012. Before that major migrations were on Friday and Sunday Nights (3B, 1L, etc).
maybe first week of febuary i mean
next satellite arrive to 28.2e
need to keep spectrum to see mid next weekend if signal strange
before 2e come
M60
Northern England
Didn't realise most major migrations at other locations were over a weekend. Did Sky's ex 2D TP's migrate on the 18/02/12 too? I seem to remember them going a tad earlier than all the others?
Yes. There were band C migrations before that date (C5 for example), but 2D migrations were on the 18th and 25th.
dvdfilm
1.5m dish
spain
The question is whether 2E,once arrived,will activate a couple of tps first(as did 2F) for more testing,or the migration procedure will start straight away
It seems to me to be inconceivable that they would go straight into mass transfers without some testing first: It's a hostile environment up there in space and apart from the beacon and some telemetry, they cannot possibly know if all has remained well (ie No degradation or damage) without testing.
M60
Northern England
Cheers Heuvos, the same migration plan can probably be expected again.
dvdfilm, I suspect that will be so for testing prior to mass migration. I think the new BBC 2F TP appeared a few days prior to other 1N C band migrations. 2F arrived 10 days before 1N's C band migration took place.
skomedal
This and that
thule
My thoughts exactly :D
Pig in a poke springs to mind
"" something that you buy or accept without first seeing it or knowing what it is like, with the result that it might not be what you want ""
Just so long as it isn't a poke in a pig. I'm not a Lib Dem.
Sooner or later they'll have to bite the bullet.
good morning to all
astra 2e
33.3e
about astra 2f ses press 22.11.2012
after one days start 11023h
M60
Northern England
It looks like the Disney TP on 10862H is being cleared out as services are now duplicated on 11914H and their 1N spot TP is currently only half full anyway.
Maybe SES will use this TP for initial testing, even if only for a few days?
tothbros
Budapest, Hungary
sky is probably moving their channels to a PE beam...
Pietclock
125cm
SE Germany 50°N/11°E
I think the first transponders to move will be the four data carriers.
