First of all, when positioned on another position than intended the footprint will be different.
For me there was almost zero change in the signal I received from 1N at 2E and 28E. The present test is half that difference from 2F's permanent location so I would expect changes to be small.
For me if the UK beam is less than 15dB down on the beam we are currently seeing on 12325H it looks like we will be good to continue using the exact same equipment we currently use for 1N reception.
welshman234
sky hd uk, 80cm kathrein dish,vu+ solo, humax f1 fox for hotbird 13
frankfurt
I hope you´re right on this.....
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
we hope next week start low band
Bkindfaith could you kindly tell us where in Europe you are to help us orientate ourselves when evaluating our own signals etc.
Cheers
A few hundred miles southeast of Moscow by the looks of it.
BlindFaith
TBS 5925
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Do you live in the eastern part of Europe? 2E is only in the advantage of the Western part of Europe.
welshman234
frankfurt
Further west than you, and a lot warmer. And I'm talking about 1N and 2F, not 2E (yet).
C0re
Ede
VU+ Solo SE
With 2E I was referring to the position 2 degrees East ;)
it not too far 2e next june 2013
Which is a big flaw in using 28E as the major slot for the UK. A lot of the work going into tightening the footprint is wasted because of this.
the pe beam 2e can move coverange have east beam
we wish expand beam
BlindFaith
TBS 5925
12441V now active
strs65
LNB1: Smart Oxid
Motor: Amiko DM3800
BlindFaith
TBS 5925
still active but not as strong as the others..
I'm guessing this is UK beam. Just visible here and about 10dB down compared to 12185H.
