DX Excalibur
- Oct 3, 2010
- 3.0m PF dish C&Ku band 103E-40.5W/1.4m PF 75E-37.5W, DM 500HD,TBS 5925/6903
- RO, near Bucharest
Does your spectrum have measles?I see small bumps on spectrum.
Nice findings! Means the transponders are switched on, while the uplink transmitters are not (yet).11582 H, 11597 V, 11671 H ready to be activated tomorrow ? I see small bumps on spectrum.
Same thing happened on 17.06, a day before 11464, 11479, 11509 were activated, small bumps could be seen on spectrum.
Sorry, did not have glasses on. miss typed. try 11477 V ( as all sites show ) Sorry once againTry 11447V 23000 3/4
Not on flysat, but blindscan picked it up!
El mas potente de 13.000 canales en 48 satelites.
11477V23K 8/9= 20.00dB Signal/SNR100% AGC99% BER 0
If the 75E LNB is single I would think it's unlikely to be that as the disecq would not be sending power to it?Can this signal be thru diseq from 75E?
But if you can't get the UK spots why would you want a Freesat box anyway? FTA on the Europe beams is pretty much limited to a few music channels, news and shopping. Those viewers can use a generic box or swap to a Sky box if they want the 7 day EPG, but music and news doesn't really need a long range EPG.Is the end of Freesat receiver use outside the UK spotbeams imminent?
This would seem to indicate the 4 remaining tp's can only move to the UK spot next week:
http://frequencyplansatellites.altervista.org/Astra/Astra_2E.pdf
No home tp (tp 115)= the receivers are more or less useless.
Sadly I can't take the credit. I believe those are made by @Marcus_21I'm curious to know where those frequency plans originated, thought Timo had produced some
Although I believe interest might be slightly limited by the fact that any channel on the Freesat home transponder can't be included on the Sky EPG.Timo is probably right that in terms of Freesat weighing up their options, as all the PSB derived channels are on spots anyway, soon most likely to be joined by the CBS and other entertainment channels going spot then there's more to be gained by switching the FS Home TP spot and finding channel operators deals who may want to get on-board.
Yep, whoever went on it would be for FS inclusion only as there's no Adaptation Hub on the FS Mux output.Although I believe interest might be slightly limited by the fact that any channel on the Freesat home transponder can't be included on the Sky EPG.
