Hi Caz,
Of course. It's stored in a binary file so I have to make an export utility. Is a text file OK?
If you are comfortable with releasing the data to a wider audience we would welcome you uploading the file here.Hi Caz,
Old favourite here too, today at 14.00hrs whilst in Torrevieja, 10818 V 22000 showed a pixelating picture with 1.4m dish....first time for some time !!On a totally non technical level astra 2E levels seem much better today in cloudy Gandia 10818V, my old favourite, is back at 65-67% SNR (quality) and no pixellation and most others 2E TPs also better.
@LP there is something wrong with that install. I've done several 1.4m installs in Torrevieja over the last week and they work fine on all transponders. 10773H is about the worst. Did an alignment in San Javier too and that also worked (just) on all transponders. Has the dish been properly assembled with the rubber spacers between the dish face and the backmount? What make is the dish?
It looks quite bad over Manchester way, would the BBC uplink from there now?There's some rough weather around the UK at the moment, so some uplink stations could be affected by this.
