- Dec 10, 2004
- 1.2M Channel Master, 1224 motor, VU+ Duo 2
- North West
You still haven't posted your signal quality levels, for various satellites, and transponders, Horizontal, and Vertical, nor have you mentioned if you've used the Positioner Setup option, in the menu, to peak the signal quality readings.
If the signal quality is that different, in both receivers, then you need to check your Latitude, and Logitude settings, in both receivers, especially Longitude, as negative Longitude = West, Positive Longitude = East.
Personally I wouldn't have attached the Diseqc switch until you had set your motor up, by using a direct cable, from your motor, to your receiver, but as you now seem to have it all working, then that point is moot.
A different image shouldn't make any difference, to your setup, as most images are similar, but different receivers can give wide variations, in Signal Quality readings.
Try using Dishpointer.com, to find an accurate Latitude, and Longitude reading, by using your postcode, then zooming in on the map, while moving the green icon, to your property, and where the dish is sited.
You could also try setting the USALS option to No, then manually aligning your dish, using the positioner Setup option, to find the appropriate satellite, peak the signal quality, then store it at that number.
