HI CH,My webtv won't let me open the file up.Thank you,I think I can put the 5'' pipe to the west side of the old one.I am hoping that this don't stop me from getting the other sat(trees) The old one is in a good spot. It would be to hard to dig it up and installed the new one.When I get the5''pipe install I will cut the3''pipe down.Are you sure Its 5'' OD pipe, It seem pretty big and heavy. 5''OD x21'ft ok.Now I am having problem with my feed (f/d 36'') I am getting odds on one sat and even on the next, This with a 2c&2ku no servo motor. I don 't get it. I get the samething with a feed with a servo motor. I found my chaparral installtion manual book. C-band vertical top and c-band horizonal left, ku horizonal right,ku vertical bottom. I can't tell which one is top or bottom, How can you tell when your lnb is vertical or horizonal(c-band is at 12 oclock is vertical) I am talking about ku, I may have it turn the wrong way down or up. I go by the writing on the lnb the mean the face, The F connector could go anywhere. Thank you jackp n Chicago
