- Jan 1, 2000
- Age
- 60
- Website
- www.sat-elite.uk
- UK
I was hoping the overrun might be somewhat less than half of the original 127 pulses at 18V.the motor run to half speed !!!!
pulse is 2.5 ms long instead of 1.2ms .
i put a at89lp51 in place of 89s52 an now i manage pulse from encoder at real speed (pulse every 1.2ms).
i have adapted firmware to show 5 digits number (1 to 65535) .
on AZ turn i receive about 50000 pulses (for 180°) on EL movement it is 30000 pulses!!!!!!
If so you could also try at 9V and 27V to work out the best slow start/stop voltage from the power supply.
The above is assuming you can tap off additional secondary points from the transformer.
