I have been working on the EGIS engine for several months, I adapted my JPC-POSI (positioner) to this engine.
AAL41 and FEMI have this model.
I added an autofocus function based on the AGC signal, it's less precise than the SNR quality signal but it works very well.
I also added a function which allows you to approach a position always from the EAST (by going beyond the position to then return), this allows you to make up for the mechanical play.
I also did the same thing for the elevation.
To be able to test in the best conditions, I mounted an old generation LNB (9.75/10.75 band selection by 14/18v) on a mechanical polarizer.
Using a small adapter board, the SF8008 is configured in user-defined LNB mode: the 22k is diverted to activate the band change and the 14/18V changes the H/V polarity.
I would like to know if any forum readers would be interested in my EGIS positioner version or in this adapter intended for polarotor chaparral type installations.
