Express 80 (will be 80E) & Express 103 (will be 103E)
Hi @tempo,thanks for finding.I'm at 80.0E and I found a signal at 11473 H. Because I'm not sure,please check if there's a valid signal test?Thanks.
Look,after I posted,the signal disappeared.Seems to confirm that the test signal was real!
Now is test carrier on 11474 V?I'd recommend others check it out.
anto@
italy
no signal V
Thanks anto@,what signal do you have on your spectrum?
added spectrum atm:
anto@
italy
now the signal is off
anto@
italy
using the instrument in real time spectrum, if a signal is switched on, the frequency is immediately seen on the spectrum
11540 H-test carrier
11540 H is off atm
10980 V-test carrier
anto@
italy
11044 H segnale forte
Thanks to all for checking the testing!
I think there are 16 * 54 MHz transponders arranged both H/V like the previous Express-AM22:
10981 - 11044 - 11106 - 11169 - 11481 - 11544 - 11606 - 11669
Then with a total of 20 Ku transponders and just one fixed Ku footprint, there will probably be 4 somewhere in the range 12.5...12.75 GHz.
Confirm 11044 H
11044 V-test carrier now
anto@
italy
66 mhz tp
  • 80 est 1.pdf
11540 V-test carrier(weak signal in my area)
tempo
47.5N, 42.2E / Russia
Where are you?
Russia, 47.5N, 42.2E
Screenshots of today's test carriers
11606 V
11672 H
11672 V
11482 H
11482 V
11543 H
11669 V
10975 V
11045 H
11045 V
P.S. Please don't pay attention on the peak 10750 V, it is an interference from the local oscillator (LO=10750 MHz) of the neighbor circular LNB.
tempo
11545 V
11606 H - is active at the moment
10981 H-test carrier now
11106 H-test carrier now
