Gibertini OP150 unders spanish sun!!
kamaleon
skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
str8 frum da wesside innit?
Well in that case what does "C band tolerance" have to do with it? It's a matter of optics: you receive the c band satellite off centered, there's nothing overwhelming about it, it's just the way it is. It would make sense to talk about tolerance if you had your dish pointed at 34.5W and you were receiving 34.5W with the off centered C band lnb which is not on the main focus but would still look towards the centre of your dish. :-HB Anyway, nevermind, forget about it, if you don't understand I don't care :D
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
:confusedthanx for your time waisting anyway...............
kamaleon
If you think helping people out on forums is a waste of time, then I am sorry for you :)
guest poster
registered
Great photos Pipino...
I checked the dimensions on those C Band feed horns.. they exactly match the f/d ratio- inner scala cone angle on the Channel Master KU feedhorn... Do they make a noticeable difference between them fitted or not?
I think you are missing something here. If the dish is pointing at 34.5W and you are receiving KU, everything is centred. Looking at Pipino's pictures I'd guess the C band LNB's are about 15 cm off centre which with the 1.2 metre LNB arm equates to about 7 degrees. The dish must be moved 7 degrees so the C band LNB comes into focus. Obviously the tolerance that Pipino is talking about is the small aberration due to the LNB being slightly off centre, not some tolerance caused because the dish is not correctly orientated towards the satellite for an off centre LNB.
pipino
Back from the dead
:)thats exactly what i mean .spot on
@pedro2000uk
do you mean the final position of the 3 feedhorns on the arc line when facing the LNB from the front?
guest poster
registered
pipino said:
@pedro2000uk
no ...just the internal cone shape / scala rings ... see last two posts in 'lnbs in the raw' ... the internal angle = 45 degrees as does those C Band feed horns.
pipino
Back from the dead
hi pedro ,
here is my actual set up on DMS BSC421 C Band LNBs
on Zinwell LNB the Plate goes accross verticaly as the shape and design of the LNB is different. i need to take some pictures again showing the whole setup including the offset feedhorn as i dont have any left in my workshop..cheers
---linear -------------circular
Pipino, how are you switching between LNB's?
pipino
Back from the dead
i use diseq X4 switch ,but i will change it for the "Spaun SAR 411 WSG" soon as this one sometimes just dont do the switch correctly
pipino
Back from the dead
just snaped this strange channel from Guinea RTG on intesat 907 27º frequency 3936 R SR:4549 1/2
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
pipino it's rather unlikely but i will dare to ask you about 70W. This satellite has no official coverage above Europe but the most analogue (suppose in PAL N) carriers on. Are you aware of anybody in Spain and especially the Canarias with a monster dish can get a noisy picture using high LT ?
pipino
Back from the dead
hi,
looking at the coverage map of 70ºW ,i would say it should be possible but with at least a 6M monster dish but may be even with a good 4.20m too,,shame i dont realy know anybody stationed in canary island with that type of gears
deepbluesky
I see. In theory you could be right but just to mention some exceptions:
72E NE Ku Asia Beam received on 4.60m in Eastern Hungary
95E India Beam also one frequency once received instabile on 3.70m in Eastern Slovakia
43W/3874V Americas beam received in Italy and Greece on 3m
74W Ku Band NA Beam analogue was received on 1.20m in Western Ireland
And 70W should be easier to locate because of still analogue transmission.
What a pity you don't know anybody there. But it's worth to try it also on Madeira where neutron has a 4m and why not also in Portugal or Southern Spain ?
pipino
Back from the dead
yes indeed ,after seing Mr shumacher from Brasil ,its possible to get anything realy just a matter of trying ..from my part i wish i could put a 6 monster dish on top of my building but surely i will last only few days as a free persone as my neibours are realy pissed off with my dishes already:p,just this afternoon i´v put my new 90cm FIBO dish ,tommorow i will post the pictures..regards
