How big a dish for fuerteventura
Razor2
non
igiveup
I used to be good at all this sat stuff,, now I can't even log in..
With that said,, can I ask how big a dish do I need for to watch BBC in Fuerteventura.
Currently all I have is the Spainish Freeview,, 20 odd channels all in spainish bar one. Back in the day I might have figured it out myself, But I must really ask for help now.
So what size dish do I need to pick up BBC in Fuerteventura.
what was your old eMail address supplier ?
Razor2
non
igiveup
Old email gone,,, But you wont need to come and set up the dish this time,, just tell what size I need,, or if there are other ways.
R.
Razor2
non
igiveup
Look ..
Of course I remember. Just before the addition to our family
You've chosen the better island to live on, is it a bar you've bought ?
A minimum of 3m according to AS's map.
I've got one here, but it won't quite fit in the suitcase.
Razor2
non
igiveup
Just old and broken now,, have to sit on the balcony and sizzle because there in nothing on the box. The Bar across the road has been gouging me at €1.50 a pint when there is a match on TV.
So if I had the right size dish I could stay home and gouge the fridge.
Will your balcony handle the weight of a 3m dish ?
Does it face SE ?
Razor2
non
igiveup
on top floor,,, but will it need to be 3M ?
Too big,, might stay in the pub so..
Adam792
Cheltenham
You could get the Freeview back-up feeds from Intelsat 27.5°W on a smaller dish maybe? BBC1, BBC2, ITV, C4, C5, CBBC HD + the rest of the BBC channels in SD. They're in BISS.
Don't know exactly how big a dish that needs in the Canaries but I didn't think it was massive.
What dish size does that pub have?
mikeisyou
Feed Hunter
England
Is it Premier League, Championship or England games you're interested in watching?
Reception for 27.5w to watch BBC1, ITV etc is minimum 1.2m for the Canaries.
What is your broadband download speed? Speedtest.net
Razor2
non
igiveup
The bars here have huge bloody things ,, way too big and I would not bother at that size.
As for internet 15MB down is best I can have, anytime I ran speedtest I was getting 15MB, so not bad.
Thanks Guys.
Adam792
Cheltenham
1.2m-1.5m for the UK PSBs on 27.5°W would probably be your best trade-off then! Otherwise use a VPN and the internet.
Seemed quite a popular set-up when I was in Lanzarote just before el confinamiento...
Terryl
Custom built PC
You can look it up here....https://www.satbeams.com/footprints?norad=39285
This is an active foot print map for that satellite.
Just zoom in to your location and click on it, this will give you an idea on the dish size needed for error free reception on that satellites beam for your area.
Ku band shows about an 85 cm dish, don't know what band/channels you need.
