Scubadan77
- Nov 23, 2015
- Age
- 47
- Famaval 1.4m Off set dish, Gi8120 Satellite receiver
- Oriheula Costa, Spain
thanks guy for your advice, i did have a 80cm but have lent out for a while.
I can get my hands on 1m so will try that also try setting up the diseqc.
Your lnb is roughly level, judging by the pics, 19.2 needs to come down by about 16 degrees. Not sure how good, or bad, the M dish is.
First thought after looking at the photos.....have you tried the monoblock fully forward and fully back in relation to the dish face?
As the feedhorns of your monoblock-LNB are about 55 mm apart (I reckon from your photoos), a 100 cm dish will be too big. That won't work, either.
For this LNB I guess a 75 cm broadth dish would be best, in your area in Spain. So 80 cm would also be OK.
Either way, measure its girth! that will give us a better chance of advice.
Intending to go to Leroy Merlin next Teusday at La Zenia, it you ain´t fixed it by then, let me know!
That's true if you use the correct LNB but the LNB is probably optimised for an 80cm dish. The distance between the two heads needs to change depending on the size of the dish.a33 , you say 100cm dish will be to0 big, why??
I thought bigger dish would give you a stronger signal???
Finally got round to running the tests with the two 4.3 monoblock lnb´s I have. As suspected had problems getting a good balance on a 60 cm dish. Managed to get a trade off receiving both at about 9 dB, but a nudge either way gives great improvement on one with a big loss on the other. Didn´t have a true 80 cm dish, so jumped straight to the Laminas 100 cm dish. Got both satellites in excess of 12 dB with no problem. The sharp eyed amongst us will stop the LNB skew is a bit too much, caused by the holder design not allowing me to drop it any more. Probably would have got a slightly higher reading.
Either way, it proves the 4.3 monoblock will work happily on a 100 cm dish, even though it is designed for an 80 cm
I mounted it on 19.2 E because the " holder " on the Laminas would mean I have to strip the dish down to get the LNB in place correctly. Using a Triax or similar dish I would recommend using 23.5 E as the focal point, 19.2 E being much easier to receive. ( Also, most HD ch´s are on 23.5 E and need more SNR than the SD on 19.2 )thank you Milamber, so there might be hope for me using this W90cm x H100cm dish.
I see you have clamped the right side (19,2E) , did this make a difference???
I am waiting to hear from the suppliers what size needed for the monoblock .
I have no doubt it will work, and work well on that dish. Just wish I had a Duo or Smart 4.3, designed for a 60 cm dish to run the same tests. May have to beg, borrow, or steal one!Good testing, Milander!
So, scubadan77 is in luck, assuming his monoblock has the same dimensions as Milanders. And scubans dish is 90cm, so that would be even 'better'.... ??
Greetz, A33
( Or contact a fellow forum member who has one! )
Well, I have one, but I am living in the Netherlands...
Greetz,
A33
I only gone and done it !!!!
I had a go over the weekend, got to say it wasn't straight forward,
it took a bit of tweeking and patience !!!.
I aligned the dish to 23.5e on a single lnb,
I then change to the monoblock and clamped it on the left what is
23.5e but couldn't get 19.2e. I then swapped and clamped it on 19.2e
and had the same problem. it was frustrating it was like they needed
to be further apart . I couldn't think which way to move to get them both to work.
anyway i loosened the dish and keeped going between the 2 sat untill i got both.
i think it must have been pure fluke!!!
also i have a new meter what i don't fully understand and i need to learn ..
this is a great forum full of knowlegeable people who are happy to pass it on!!!
thanks
