itchybag
- Jan 10, 2016
- Age
- 44
- 1.1 stab motor with VU+ SOLO 4k, dm800, prof 7500
- earth
yeah, watched a load of youtube vids for tips n tricks. Have to make do with what you have. The correct tools would make it a breeze but for 1 offs there is only so much you can spend thoughGood progress. Having the right tools at the right time sure does help. Or friends with them.
A sand or bead blasting cabinet sure would be nice for the rusty, corroded stuff.
If you've never used Evapo-Rust you'd be amazed at how it works versus electrolysis. I cannot say more. Electrolysis to remove the crust and then a soak in it would bring big smiles.
Kroil. You gotta' get a can of Kroil!
Helicoil kits are not too expensive for a one-off fix. They don't overbore much compared to a drill to the next size up. Or....and friend with a Time-Sert kit.
The old mig or tig a nut to broken studs and bolts works wonders. Sometimes, usually.
Drilling into twisted off hardware and making sure the pilot hole is centered is a pain. The bolt or stud becomes work hardened in the exact place you need to drill. Sucks!
A steel or copper sleeve slipped over the protruding threads or inside of a recessed bore. Perhaps telescoping another piece inside. Makes for a drill guide that should let you start the pilot hole centered.
Those diamond Dremel-type cutter bit assortments you see in hardware stores are awesome. Using the above sleeve guide you will be able to grind a starter hole right smack in the center. Let the diamond do the work. Squirt cooling water to flush the cuttings. A small set of end mills using the same procedure works.
That last photo of the mounting flange would be handled well with a small bearing knife. I have a set from small to large. Really makes pulling a tough CV axle from vehicles quick work.
Too bad you don't have a hobbiest powder coat rig and able to send the wifey out while you steal her oven for a bit!
Good job!
yeah, was thinking of either replacing it with a piece of iron bar and drilling and tapping that to about 6mm and bolting it from both ends or even just a suitable snug nut n bolt. I could have just as easily left it, cleaned up all the other parts and assembled it as is what i would have probably done if we were heading into summer.I used a hollow stainless steel/INOX tube to replace the weird bolt in there and retained it with a normal nut and bolt.
Gives you more freedom to choose the diameter of the hole to drill - within reason.
yeah, would be nice to get all the parts powder coated and rid of all the rustIt's an infuriating bolt and to do a full restoration, you need to remove the top triangular plate in order to remove the plastic surround. But depends on how far you want to go.
wonder if this would ease the plate off using a long bolt in the centre so downward force can be applied while pulling the plate up?.
gear puller
will do, i will distribute the load foot print and see how it goes. the cheapo puller may break first. we will find out. need to drill that centre pin out yet so hopefully report back at the weekend.It will either remove the plate or snap it ! Those plates are made from some cheapo alloy using Chinese píss as hardener
I think I saw somewhere that someone had made one from an aluminium block and machined it to the exact size, not sure how they cut the central splines if there are any present?
Give it a go with the puller and let me know how you get on, I got wan 'ere needs to come off.
What's the diameter of the pin? I'll go though with a 6mm bit first then full bore. The gear puller will be here in a few days. The hole on the plate being offset may cause issues with the puller. Hope with the 3 claws it will do the job.
that bearing knife set looks a far better option than the 3 claw gear pullerI take it you don't have auto parts stores that rent different tool sets and return them for free?
Single size Helicoil sets aren't that expensive. If you do use a jaw puller. Tighten the bolt. If things don't come loose, don't hog on it.
Instead. With a fair amount of torque on the bolt. Hit it dead on smartly with a ball peen hammer and see it it will tighten a bit more.
My preference where a jaw puller may break a cast item:
Bearing knife set
The pin is not strait but conical , the M6 end with nuth has the biggest diameter .What's the diameter of the pin? I'll go though with a 6mm bit first then full bore. The gear puller will be here in a few days. The hole on the plate being offset may cause issues with the puller. Hope with the 3 claws it will do the job.
wierd if its tapered theres no real need need for the nut. the weather is dire. all i want for Christmas is the pin out and the top plate off, in 1 piece ;o)The pin is not strait but conical , the M6 end with nuth has the biggest diameter .
I
See this post Help Required - Searching for a jaeger smr 1224 puls magnet
The pin is also named Spigot make a search on that on this board and you find alot of topics
Once the pin is out try to turn the plate over the shaft before you use the puller .
