Jaeger 1224 restoration
Trust
Nijmegen Netherlands
In one of the Spigot topics you can see the use of that M6 end , its to attach a special puller
itchybag
1.1 stab motor with VU+ SOLO 4k, dm800, prof 7500
earth
at one point i was thinking of using a slide hammer dent puller but needed an adaptor so tried heating it and hammering from the other side. need to get back on it hopefully tomorrow.
ArloG
12' Fiberglass Dish, C2W & Geosat Pro lnbf, Titanium ASC-1, Osmio4k, Zgemma H7 Client
N. Central PA, USA
itchybag
earth
itchybag
earth
itchybag
earth
Did you pull !
the 3 claw puller was junk, 2 many weak parts and pain to get it aligned due to the main mount being offset. In the end i just tapped the side of the plate with bolts in place back and forth and it eventully moved so you couldnt see through the pin hole. I scribed the underside shaft to make sure it wasnt turning the whole mechanism.
itchybag
earth
will have to re tap the pin. that took way more force to knock out that the top plate.
