Linux software for real time signal?
statalite
SF8008
DiSEqC motor with 1m dish
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
Hi Guys,
Is there any software for Linux which can give me signal readings (more detailed that percentage) for a DVB-T / T2 signal in realtime?
This is for the purposes of fine tuning an indoor antenna.
As I only have a PC with Linux I don't wish to go down the external meter, raspberry pi or Linux stb route.
Current hardware is the Xbox one usb tuner.
So far I have found Kaffeine but this is not ideal.
Kind regards
statalite
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
More about the Xbox tuner component information which maybe relevant.
I'm also using Linux Mint 20.
Kaffeine currently gives decibels on one already tuned in channel, which isn't any use if I don't have enough signal to tune in. I know one mux is borderline signal for me.
I have found this thread relating to TBS cards, maybe @CrazyCat can help? :)
Disconnect all nearby unneeded DC power supplies, the type that comes with anything electronic these days -when I tried to setup an indoor aerial I found it was these that were pumping out interference all over the place. Even the PSU that came with the aerial caused trouble. In the end I found powering the aerial from a USB socket on the TV worked best.
A cheap RTL-SDR dongle would give you a live spectrum I believe... not an area I'm well versed in so don't take my word for it :)
updateDVB has a decent go at showing quality values in dB.
Of course that's on a single channel, so may not be suitable for continuous signal checking. I can check if the signal changes whilst on the channel.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
Thanks but this is still the case with nothing else connected. Good advice though.
This is the type of cost I'm trying to avoid. I have satellite so it's not crucial my terrestrial reception works but would like it too. :)
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
Regardless I will give it a go, getting it going will be challenging I feel but worth a go. Thank you.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
I can see I'm going to struggle with setting this up. I should mention that I have very basic Linux command knowledge.7
I went here under the installation section
I'm stuck at the v4l-updatelee-master stage, I have downloaded the dependencies using
sudo apt-get install git build-essential linux-headers-generic \ ncurses-dev libproc-processtable-perl fakeroot libelf-dev libssl-dev \ bison flex pigz pkg-config
then I did the smaller repository
git clone --depth 1 https://gitlab.com/updatelee/v4l-updatelee.git
, but not the debs bit,
changed the folder
cd v4l-updatelee
when I go to the next bit about compiling (I have 4 cores)
sudo make -j4 deb-pkg
I get this error
Makefile:609: include/config/auto.conf: No such file or directory
Makefile:655: include/config/auto.conf.cmd: No such file or directory
*** Configuration file ".config" not found!
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
Makefile:658: recipe for target '.config' failed
make: *** [.config] Error 1
Can you see where / how I have gone wrong?
changed the folder
cd v4l-updatelee
I get this error
I'll look at that ASAP statalite. A little busy ATM
te
changed the folder
cd v4l-updatelee
I get this error
Leave that and use the DEB files, which are precompiled updatelee packages.
Download the last three debs (headers, image and libs).
Unpack and copy to your Home folder using Terminal command dpkg -i linux-headers-5.4.54-udl+_5.4.54-udl+-2_amd64.deb (other two debs similarly).
Let us know if that gets you a file called udl-updatelee placed in your home folder. Then you just need the updateDVB application.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
I have now downloaded the 3 DEB files. I opened them using the GUI package manager, figured it was the same.
The package manager said all three were already installed.
I have the v4l-updatelee folder in my home folder, did you mean v4l?
The updateDVB program I get from here? download the compressed file then how do I install?
Sorry, yes v4l-updatelee.
deb files for updateDVB here, bottom three (not the tar file)
I haven't used these, I compiled the app before the deb files became available, so I'll be interested to know if they get you the app.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
I followed your link and looked at the DEB files, instead of the 3 files that looked similar to the previous link, I tried the top one, this again said already installed, I was surprised but I typed in updateDVB into the start menu and it comes up as a program. I started updateDVB but cannot get it to work, I think I have configured it correctly, but no graphs or readings.
My TBS T/T2 tuner's out of the PC at the mo. if I don't have time to replace it tonight to check my updateDVB settings against yours, It'll have to be tomorrow.
Just sorting some PC gremlins at present, I have updateDVB running but the video driver's messing up my display.
Anyway, your settings appear to be OK, same as mine apart from tuner type.
What's different in your third pic is that you don't have the Spectrum Scan button (see my pic), so you can't scan the spectrum. I've had that problem myself on one that I built a while ago. I'll try to think what I had to do, I think I just rebuilt he app.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
@Llew
When you say tuner type do you mean DVBT or tuner name, as I can see you are using the DVBT option, so the same as me?
I think I messed everything up, from memory in the v4l folder I did a command to make modules like here but this took ages and I couldn't do the next bit make modules_install and now when I load the program it says no adapter found so I messed it up I think. Do you know how I can start fresh without reinstalling the whole OS?
Yes, DVBT like you, I haven't bothered with naming the tuner.
Remove v4l-updatelee folder with Terminal using rm -r v4l-updatelee, then redo it, but you don't need to make modules, that's only if you're updating.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
I'm going to have to reinstall the OS anyway as my usbs and sound have gone also. Hopefully back up and running shortly and can try again fresh.
Snap. I have problems too with updateDVB on the PC it's currently on. So - a fresh OS to install.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
I'm having an absolute nightmare, the SanDisk sad I use I normally 'sanitize' it using their own software for some reason it refuses to do this it has worked in the past so completely baffled. The same software also refuses to create a sanitize boot usb. I give up. Have been able to wipe with aoemi, never used before but has done something to wipe it seemingly. Don't know if the drive is defective, doubt it. Just wish I setup a timeshift system restore in mint then I wouldn't have had these problems. You live and learn.
