- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
Peak the skew using 11265 V & H, as the frequency appears on both polarisations it will make it easier to tell when it is correct - perfecting the skew will minimise interference from the opposite transponder.
A round dish will suit the Inverto LNB better than the Sky dish, but the the zone 2 will have more surface area. If you plan to motorise the dish then a non-Sky dish would be better, if staying fixed then a zone 2 + Sky LNB would be my choice.
