PGB
- Jun 20, 2010
- Age
- 81
- Teleco Magic Sat 2002A in Camping Car with 85cm dish this is connected to a Sky digibox.
- Expat in France
July 5, 2010
Hi Boatahome,
How to modify the criteria of Astra 28 Satellite on the Magicsat 2002A system using the remote control only
1) Switch on the system; make sure that it is set to the programme number that you normally use to get Sky.
2) When the antenna starts to move press the stop key to stop the antenna
3) Press the menu key to get the main menu screen
4) Move the cursor up to the ‘Locked Menu’ position and press the ‘1’ key 4 times to unlock the menus
5) Move the cursor to Programmes and press the menu to select.
6) Select AUXILIARY, and press menu to select
7) Select Sat Name, (this should show Astra 28E SE). Using the left/right cursor keys, change the satellite to Astra 28E NE.
8) Press Memo on the remote to store the new settings.
9) Select Programme Menu, and press menu to select
10) Select Main Menu, and press menu to select
11) Then Select Locked menu and press ‘1’ key 4 times to re-lock the menus.
12) Exit Menu
13) Close the dish down by pressing the ‘down’ key. Once this is completed you have now stored the new data.
14) Restart the Magicsat and it will now search using this new data.
DO NOT CHANGE ANY OTHER DATA
Please respond to this post to let others know that it has worked for you.
Regards
Peter B
Hi Boatahome,
12) Exit Menu
Regards
Peter B
