Mike Richards
- Sep 7, 2010
- Age
- 73
- Magicsat 85cm; Sky digibox and Teleco Magicsat controller
- Dorset UK
Can I just say a HUGE THANK YOU to PGB in France. You have just saved me £800! We have struggled with our Magicsat ever since it was installed. I was so fed up with it that I had seriously considered taking the professional's advice and spending another £800 to have the system upgraded to the latest version. Since spending £2000 to have the Magicsat installed in 2005 on our then, new, motorhome it has proved useless on so many occasions. Nothing is more galling than to roll up to a lovely wildcamp spot in France, surrounded by others all watching their tv's only to find that you're the only one that can't get a picture..... Following PGB's instructions I have today got a clear and repeatable signal from Astra 28E. (I say repeatable because I couldn't believe my luck the first time it worked and so repeated tuning in three or four times to check that the system would continue to work!) I have had nothing but excuses and poor/dis-information from everyone I have talked to in the industry. But today, with the help of PGB I have cracked it. THANK YOU AGAIN. Mike (cock a hoop) Richards
PGB said:I have just received an email from Teleco UK Agents, with the following NEW criteria. It is very important that you change both the criteria for Astra 19 and Astra 28,2E
How to modify the criteria of Astra 28 Satellite on the Magicsat 2002A system using the remote control only
1) Switch on the system
2) When the antenna starts to move press the stop key to stop the antenna
3) Press the menu key to get the main menu screen
4) Move the cursor up to the ‘Locked Menu’ position and press the ‘1’ key 4 times
to unlock the menus
5) Press the ‘8’ key 4 times to obtain the hidden ‘Magicsat menu’.
6) Move the cursor to ‘research criteria’ and press menu to select.
7) Move the cursor to ‘Sat name’ and use the left and right cursor keys to find ‘Astra 28’
8) Move the cursor to ‘Criteria’ and select number ‘1’ check all 5 criteria against the following table and modify as necessary.
Criteria Frequency Pol. Signal Mode
1 12207 MHZ V Y Digital
2 10714 MHZ H N Analog
3 11322 MHZ V N Analog
4 11307 MHZ H Y Digital
5 •••
9) Move the cursor to ‘Sat name’ and use the left and right cursor keys to find ‘Astra 19’
10) Move the cursor to ‘Criteria’ and select number ‘1’ check all 5 criteria against the following table and modify as necessary.
1 11494 MHZ H Y Analog
2 10964 MHZ H Y Analog
3 •••
4 •••
5 •••
11) Note. Any changes necessary are only performed using the left/right cursor keys. They can not be added using the number pad.
12) As long as Criteria 5 has 3 dots shown in the ‘Signal’ position the other data for this criteria does not matter.
13) Once all the data has been checked/modified, press the ‘memo’ key. You will get a message on the screen saying ‘Data Stored’
14) Exit from all menu’s.
15) Once you are back to the main menu move the cursor back to the ‘locked menu’ position and press the ‘1’ key 4 times. This will re-lock the menu’s.
16) Close the dish down by pressing the ‘down’ key. Once this is completed you have now stored the new data.
17) Restart the Magicsat and it will now search using this new data.
