- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
You skew the whole monoblock. As it is designed for 13/16/19.2°E hopefully Inverto has mounted the receive probes to account for the skew offsets of the three satellites. Then if you peak 16°E the other two feedhorns should already be in the correct positions ready to go.
Or line the dish up on 16°E and then select one of the other satellites and rotate the monoblock to peak that sat. The third satellite should then also work.
