Monoblock advice
I have decided to go with the old tried and trusted A/B switch method.
They seem pretty rare these days. I can’t actually find a UK stockist.
Amazon can get one in from Germany for £20 but that won’t arrive until after Xmas and there is a stockist in Ireland that have them. £16 delivered.
Cripes, you're right about availability - even eBay throws up no viable results.
I thought I had a spare lying around, but a quick search didn't unearth it, sadly.
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
Certain sat gear is like gold dust these days :(
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Modifying a (cheap) 4/1 diseqc switch might be cheaper. ;-)
In case of a triple LNB, the 4KUHD-solution is also beautiful, and easy to apply to a switch: oplossing komb. monoblock/diseqC switch
Cutting through two copper-lanes near the PIN-diodes VD6 and VD7, and adding two bridges (at the F-connector, or at the other end of coils L2, L3 and L4, does not make much difference I'd say); not too difficult I would say.
Thankfully the internal layout of a diseqc switch is often pretty obvious. :)
Greetz,
A33
