Chr0nik
- Dec 2, 2005
- TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
- Grays, Essex
If you are to correctly align the dish to the arc you might get away without having to adjust the declination offset angle if the angle was correctly set previously and if the angle for your location is close to that of the original location.
You should be able to peak the signal level by adjustment of the elevation bolt, possibly one sixth of a turn of the hex nut at a time. Also, if the motor is wired up you could nudge the dish East/West one click at a time around the 0.8W position to see if it improves the signal.
I've tried both and it peaks at 15.3db.
