daro2096
- Jan 21, 2009
- Age
- 50
- No setup at present
- Consett, Durham
Or they can use a unicable multiswitch that is compatible with a quattro lnb such as the Inverto Unicable multiswitch.Have you considered using Unicable LNB instead of Quad/Quattro?
They will save you investing in an expensive multiswitch and simplify the cabling installation.
Just make sure the receivers in the rooms can support unicable LNB.
For example using two unicable LNB's each supporting four receivers can be used to supply signal to eight receivers (or tuners) (without even using the legacy LNB outputs which can be either single or dual).
You will need cheap simple splitters.
