- Sep 11, 2008
- 57E to 58W, C-band and Ku, DVB-S2, 4:2:2 and blindscan.
- 38.5ºN, 0.5ºW
104 is a guide, but it will be pretty close. The point is if you align the dish using the central LNB you know it is correct and just needs skewing so the focal line corresponds with the geostationary arc. The reason to do it at 90º is to be sure the central LNB is really central. If it is not central the signal will go up and down on the central LNB as you skew the dish. And if the central LNB is not central you will not be able to get on the arc just by skewing the dish.godzillafan said:I wont need to skew the dish from the 104 position.
Is this now correct?
The key for today is that I get 19E nailed on 0 and the dish at 104 and 19E skewed in opp direction to max signal.
If the signal does go up and down on the central LNB as you skew the dish the most likely cause is your custom guide bar is holding the LNB at the wrong height, which is why Hakon recommended that you use genuine LNB holders for the initial setup. That might seem a lot of work but really it will make the job much quicker.
And lastly forget the positions from the calculator. On my dish they were way out.
