OCTAGON SX88 H.265 HEVC HD
stephan94
Bavaria
OK super good news
This morning I did a search with openbox S3 Mini
who always found the program itself,
this morning no program, wonder
Perhaps he had had a problem ??
Tururu
Assembled with recycled parts
Recycled as the owner.
..........Perhaps he had had a problem ??
The channels continue, fishing a few minutes ago (VU+DUO2). 12-10-2017 17:45 GMT+2.
Los canales continuan, pesca de hace unos minutos (VU+DUO2). 12-10-2017 17:45 GMT+2.
Marschall54
Sattelite receiver golden interstart germany
I can not receive the French TV channels from 5 West ... but I still have the Italian ones, but although I have a signal on the frequencies 11509 h 29500 (here identifies CH1026, both) and 12648 v 29500, they are not receiving!
What steps should be taken to receive French TV channels?
Tururu
I know it's heavy, but entering an unread thread from the beginning (300 post) and asking for the answer without further ado, does not seem right.
Quiet I already know the answer.
Always a "linnet" the answer will give me.
PS: The channels have good "image" and with the correct name, the rest is already counted.
Se que es pesado, pero entrar a un hilo sin leer desde el principio (300 post) y pedir sin mas la respuesta, no me parece correcto.
Tranquilo que ya se la respuesta.
Siempre un "pardillo" la respuesta me dara.
PD:Los canales tienen buena "imagen" y con el nombre correcto, el resto ya esta contado.
stephan94
Bavaria
octagon_sx88_v1.04.24_20171014_EU NEW SW - 14 10 2017
SW Update: Menü- Einstellungen - Software Update: USB - Rote Taste : OK
SW Update: Menu - Settings - SW Firmware Update: USB - Red Button : OK
- changed audio volume and mute to global
- solved some stalker server normal channel pop password problem
- solved DLNA live not working problem
- solved Multistream and T2MI can not record problem
- solved new Stalker server vod not working problem, series still not support
- added Czech, Portuguese, Spanish, Polish languages
- FastScan updates, add. region option and tkgs
All problems of recording of multistreams (with or without T2MI) is solved.
There is an additional good surprise .
French Multistream on 5 ° West is recorded with the audio.
When they look the recording on a PC or on a television which can read AAC
you with french sound .
this new SW is going to be made public as soon as possible.
I hope that this evening it will be possible.
I shall find the hammer to smash my piggy-bank.
Tururu
Piggy-bank ==> :-lol
Welcome to the club/Bienvenido al club.
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Good news,
I Will check subtitles too and then it remains only the rock of DD+........!
Pierangelo
Italy
Be' aware that the programmed recording, using epg, used to have bugs. It worked only with decoder already switched on.
Bye
Tururu
So forgive me for being cautious but can we assume that the fact it will now record French TV multistream with sound means that it's likely to be able to display the same channels "live" with sound in the near future....?
Do not.
As long as they do not purchase the license to reproduce DD+ .... no.
It is the program of the PC or the TV that reproduces the audio that is recorded.
With VideoLang, MPC-HC.
No.
Mientras no compren la licencia para reproducir DD+....no.
Es el programa del PC o la TV quien reproduce el audio que se graba.
Con VideoLang, MPC-HC.
Aha. Thanks for the further clarification. Piggy-Bank also remaining intact.
stephan94
Bavaria
Bye
It is not true.
There is no bug
So that recording works with programming it is enough to put STBY-Modus on NORMAL, and especially not on DEEP.
It works perfectly with the SX88 (I do not speak about U2C Denys)
Tururu
@stephan94
If the streaming to the PC works, using VideoLang, MPC-HC, you could see and hear these channels, while they decide whether to buy the DD+ license, for asking not to stay, in my case to make better photos, I have reflections of the led lighting in the workshop.:-ohcrap
Si funcionara el streaming al PC, usando VideoLang, MPC-HC, se podria ver y escuchar estos canales, mientras deciden si comprar la licencia DD+, por pedir que no quede, en mi caso para hacer mejores fotos, tengo reflejos de la iluminacion led en el taller.:-rofl2
PS: The commands to make a screen print from linux (E2) console do not work/Los comandos para hacer un print de pantalla desde consola linux (E2) no funcionan.:cool:
stephan94
Bavaria
@Tururu
If there is a AAC license, it must be written on the chip, it can't unfortunately be done by Update.
I don't know the option for a receiver screen copy. ??
Tururu
In other original equipment if, then the clones used it.:cool:
En otros equipos originales si, luego los clones la usaron.:p
In Enigma you can do a print of the screen, what you see on TV, using commands from console, run the test and it did not work.
grab -o
grab -d (fat BMP)
grab -p (small png)
En Enigma puedes hacer un print de la pantalla, lo que se ve en la TV, usando comandos desde consola, realice la prueba y no funciono.
grab -o
grab -d (BMP gordo)
grab -p (png pequeño)
Pierangelo
Italy
Dears,
I see step forward.
Now, it remains to fix:
- subtitles on Multistream/T2mi to fix;
- improve the LIVETV, but I appreciate it;
- DD+
Thanks for the work.
Pierangelo
stephan94
Bavaria
Pierangelo
Italy
I don't know why, but I have no Subs in t2-mi and multistream, check m6 or tf1.
RUSSIAN SUB on 40 east C band are not working too. Try, there is an Easy catch....
If You are right, It is a problem for U2C....only. But they Can fix It!!!!!!!
Grazie
Pierangelo
Italy
To record then, could be enough.....
