A couple of questions to be going on with ?
(1) Will the SX88+ come with an up to date satellite & transponder database ?
(2) Rather than throw out the old Technomate 7102HD which still functions fine can I connect both it & the new SX88+ to the motorised dish & use both to drive the motor ?
I found these two threads from back in 2012 & 2014 which suggest I can ?
It's been a while since my last installation and I want to change things a bit :-ohcrap:- I want to connect 2 receivers (one will be upstairs) to my motorised dish and both receivers also to a fixed dish. I don't need to use/view the motorised dish from both receivers at the same time - so a...
www.satellites.co.uk
On my current motorised setup (1.0m CM, Jaeger 1224 H 2 H, G Box and Protek 9760 HD) I would like to add another receiver (Dr HD F15). What I want to do is to be able to switch between the receivers so that whichever one I am using it retains control of the motor. The Protek would be mainly used...
Tony.
