problem in Gama Cart . help me
r-share
saltilite
Palastinian
I have problem in Gama card NO ATR
How to fix this problem ?
and how to write the ART
and I want SataidTeam_GammaLoader.exe
plz help me
r-share
saltilite
Palastinian
any body here to help me ???????????
Dont be so impatient. Many members only log on once a week or so and its only been 13 hours since you posted. Give it a fortnight - if you dont get an answer in 2 weeks you can ask again.
You also forget its now Saturday morning and getting close to xmas so many folks will be out shopping with their families.
There is also the point that the gamma card is only of use to watch pay tv channels for free and if the services are that important to you then you should be subscribing
Mickha
North West
There are no repair files for the Gamma card, unlike the Titanium card, but most No ATR problems are down to programming error.
Which programmer are you using?
Have you programmed the card before?
Have you got the programmer in Phoenix mode and not smartmouse mode?
Check all your cable connections and if possible try loading it on a different computer.
r-share
saltilite
Palastinian
hi to all
that my problem
I have Gama card
in the last can Work 100%%
in last 2 week , can`t work and when I put it in Humax 5400 tel me Invalid Card
I put it in Infinity USB Phoneix and put it in 6 Mhz Phoneix
and run the Loder Gama
when clear , tel me No Cleand , Card has No ATR
when I want to program it , tel me Card Has NO ART ,
any Body help me for this Problem ? and fix this Problem ?
and I search SataidTeam_GammaLoader.exe
plz english only
Mickha
North West
If your card has no ATR then you can not programme it, but you could try downloading the loader 1,1 software again in case this is the problem.
You could also try uninstalling and re-installing your programmer software,
The Infinity USB Phoenix programmer requires a serial, and USB, cable to programme in Phoenix mode, are these connected correctly?
Does your computer/laptop have a dedicated Com port, or are you using a USB to Serial adapter?
Have you checked your Com ports, in your computer settings?
If you have another card, that is programmed in Phoenix mode, like a Titanium or MII, try programming that to test your equipment.
r-share
saltilite
Palastinian
hi my frind : Mickha
My Coputer normal , no Laptop
the Com work 100 in another Receiver
and it ok in another Gama cart ,
problem in this cart only >?
when I search in the Internet , many body write the loder SataidTeam_GammaLoader.exe Fix this Problem ??
are you can Understand me ? and help me for this Problem ??
Mickha
North West
Sorry r-share,
I can not find any repair files for this card, although I have seen reference to different loaders, version 1 and version 2.2, but these are not recommended, by owners of the card, as they can damage your cards ATR.
If your programmer is working properly and the problem is with your card I suggest you contact your supplier to see if they can help.
Hopefully a fellow owner might be able to offer you more help.
r-share
saltilite
Palastinian
the programe no problem ?
the problem in the Gama cart only
I have 2 Gama Cart
the problem in 1 of them ,
plz help me for this problem
r-share
saltilite
Palastinian
any body here to help me for this problem ?
andy body here in this site ?
For the second time I say dont be so impatient! Its only been 3 days since you posted the original question.
r-share
saltilite
Palastinian
ok my frind Analoguesat I watiing ?
Mickha
North West
The Gamma card team have managed to keep their secrets, concerning this card, otherwise we would have the channels on Emu.
I still think you should contact your supplier to see if they can help.
sharegbox_mo
amd simpron 2800+
tunisia
Wt did u do r-share???? I want an answer, I will buy gama card soon and dont wanna have problem, I'm from Tunisia, that's why if I get the pb, I will put 300$ in the tray :s:s:s:s.
r-share
saltilite
Palastinian
I have the Problem in Gama Card
no body here help me for this problem
npourfarhad
GAMA OS
UAE-DUBAI
GAMMA CARD WITH OS CONTACT: no email addresses
don'tknowdon'taskme
Part Timer
DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux
Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
that would be telling
you need to program the card with serial lead and cas 3 in 6mz i had the same problem.
sharegbox_mo
amd simpron 2800+
tunisia
I have infinity phoenix programmer, 6mz Ok, but you mean wt with
and cas 3
:p:p
sorry for my stupid question :p:p:p
npourfarhad
GAMA OS
UAE-DUBAI
DEAR FRINEDS HI
I HAVE SEEN MANY PROBLEMS AND IVE RECIEVD MANY MAIL FROM FRINEDS DAILY THEY HAVE PROBLEM WITH NO ATR.
AS I READ THIRE ARTICKLES, THEY SEEMS A BIG VICTIMS FROM THIRE GAMMA SUPPLYER.YES IT IS TRUE WHEN FREINED HAVE LOADER 1.1 AND THEY TRY WITH CASE3,SMART MOUS SO WHAT STILL NO ATR THIS IS BIGE GAME FROM SUPPLYER THEY SOLD FAKE CARD ....GAMMA CARD MEANS GAMMA WITH OS SYSTEM WHEN ANY AMATOURTT ALSO NEED TO PROGRAM IT, IT IS VERY EASY AND %100 POSSIBLE TO LOAD FILES AND WATCH THE CHANNELS SO FORGET THAT FAKE CARDS IF YOUR SUPPLYERS NOT ACCEPTING THE SOLD CARD BUY THE REAL GAMMA WITH OS USE 1.1 LOADER AND ENJOY YOUR WORK11
WITH BEST REGARDS no email read the rules
