Project Fibo
Retired human
Ah, I am getting a lock on my Penta 85 on 10806H but that's the Amos 2 transponder, not Amos 3. Remplap, are you getting anything off Amos 3?
jcm193
Gibertinti 1.25 and a Channel Master 1.8
inverto black ultra lnbs
Vu+duo
south devon
This is what i get off TA3 with my Gibertini 1.25 and Channel Master 1.8 gibby is on the left and CM is on the right iam in South Devon
Zorch
TM 5402 HD CI+ Super+
TM 6800 HD Super+
TM 5400 SD CI+ USB
QualiTv QS 1080 IRCI MPEG-2 [4:2:2]
Fibo 1.20m x 1.35m Dual-Offset Gregorian Antenna [30.0°W > 57.0°E]
Inverto Black Pro
Aston DS 200 Interface
LG 42LD790 HDTV
NW Midlands, UK
Hi again Captain Jack et al,
Just to give you an idea what my 1.2m Fibo picks up in the NW Midlands... here's a quick reception report on this satellite (14.00 - 14.30) today...
Amos 3 at 4.0°W
10.723 V [30000] 2/3 DVB-S2 [8PSK] 58.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 71%
10.758 V [30000] 2/3 DVB-S2 [8PSK] 58.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 75%
10.806 V [30000] 2/3 DVB-S2 [8PSK] 58.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 77%
10.842 V [30000] 2/3 DVB-S2 [8PSK] 58.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 75%
10.889 V [30000] 2/3 DVB-S2 [8PSK] 58.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 77%
10.925 V [10835] 2/3 DVB-S2 [8PSK] 58.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 84%
11.181 H [05650] 3/4 DVB-S [QPSK] 7810 Kbps [Europe Beam]
Signal Strength 97%
Signal Quality 60%
11.222 H [30000] 5/6 DVB-S [QPSK] 46.1 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 53%
11.258 H [27500] 5/6 DVB-S [QPSK] 42.2 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 56%
11.304 H [13332] 3/4 DVB-S [QPSK] 18.4 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 51%
11.336 H [27500] 5/6 DVB-S [QPSK] 42.2 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 56%
11.389 H [27500] 3/4 DVB-S [QPSK] 38.0 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 50%
Best Wishes,
Zorch
Retired human
jcm, can you test 11389 on your Gibby? Will be a good comparison with Fibo once up.
jcm193
Vu+duo
south devon
Ok 11389.00 on the gibertini nothing at all on the channel master max 38%
Retired human
Wow, what a weak transponder. Will certainly be a good stress test.....
jcm193
Vu+duo
south devon
Come 7pm i can not lock on it at all with my dm7020hd
remlap
Wales
Lyngsat has it listed as Amos 3 mate so other than that no.
jcm193
Vu+duo
south devon
I think the strength on the amos 3 transponders varies wildly for example
Tv2 Amos 3 10759.00 V 2 Hungary DVB-S2 8PSK 30000 2/3 is booming in at 75% on my channel master
Enter Film Amos 3 11389.00 H 10 Hungary DVB-S QPSK 27500 3/4 a very 36% as i type this
Retired human
10806H Europe beam is Amos 2
10806V Europe beam is Amos 3
Retired human
Hm, looks like there are different strengths between H and V polarisations.
jcm193
Vu+duo
south devon
Amos 3 10889.00 V 5 Hungary DVB-S2 8PSK 30000 2/3 come in at 78%
Amos 3 10842.00 V 4 Hungary DVB-S2 8PSK 30000 2/3 73%
Amos 3 10806.00 V 3 Hungary DVB-S2 8PSK 30000 2/3 76%
Amos 3 10759.00 V 2 Hungary DVB-S2 8PSK 30000 2/3 76%
aceb
Prof Tuner 7301 /
Sussex
Similar variations in the same transponders as Zorch here on the Sussex coast using my 1.2 Gibby.
Retired human
OK, so I made a cardboard cut out of what I need doing. Basically, I would want to cut the existing bracket pretty much in half and attach a steel plate to the other half with cardboard in the pictures being the plate - the front to be retained (attaches to the dish) and the back discarded.
A bit destructive but I think it will be more robust than screwing the steel plate to the existing holes. Plus I am also concerned about the angle of the dish if I do this and there not being enough declination adjustment. Am I correct in thinking this?
I based the cut out on the fixed mount for the Channel Master dishes which has the same size and hole locations as the polar mount.
I've also attached pictures of the broken nylon roller on the original motor.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I think it will be a very solid job m8 ...
..always overkill and err on the side of caution ..thats my philosophy.
btw ...what function does the twig perform in picture 4 ?
Retired human
It came as part of the bundle. Didn't have the heart to get rid of it....
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..Well the dish may be an offset ...I usually name them male ...but I guess you could break the rules amd name it Twiggy ...
:D
Retired human
Hah, I wasn't in the habit for naming my dishes but with the number that I have now, I should start differentiating them.
So:
1) Fibo - Twiggy.. or maybe just Twig? Sounds more male.
2) Penta 85 - ? Van Pelt
3) 1.2m Channel Master - ?
4) 1m Channel Master - ?
This should probably be split off to another topic though!
Piltdownpaul
No.1 Spike Milligan Fan
Maybe you should start a new thread called dish nicknames!!! O-Ha
Retired human
Dropped off the bits at my local metal works place - said it should be done within the next day or so. Will report back when I have the bits back.
