So ..Saturdays post came ..and with it the 4 usn port pci backplate adapter I ordered from China..
This of course was going to receive the re-purpose treatment ...
..as the beige brick came from a period in history ..BEFORE USB was concieved .
I wanted at least 1 front unit usb port ..but decided on 2 ..as the motherboard has a suitable header ..
So ..
ports removed from the backplate ..
cut in half ...filed to a minimum to make smaller ...but I would still need to cut a rectangulat hole in the steel plate immediately behind the ABS plastic front..
All measurements taked and penned onto the front plastic and steel plate..
I couldn't fit it ubder the stand drill ..which would have made the job easier ..so had to resort to the piercing method of sreel hole making ..
A hand frill ..many holes ...join up the dots ..and file like crazy ..
I snapped to hi speed twist drills during this process..
The ABS front was a doddle by comparison...
Anyway ..
pics of the result ..but as yet not powered up and tried it ..cos I need to get my hoover and paint brush in there and make sure there are no metal filings left inside..
rgds
VS
