Well apparently it is possible to retrofit this usb driver on an existing installation of win95 ..
providing the crappy microsoft USBsupplement is totally removed from the system first (USBSUPP) ..
MS released this one (doesn't work) whereas XUSBSUPP does..
I've now added it to my previous build ..and so far is totally stable.
set up a temp test folder on the win95 desktop ..and copied the entire contents of the usb stick to it ..
Took around 3.5 minutes ..
so the ports are aperating in either usb 1.0 or 1.1 mode I'd guess ..but more than adequate to get data into win95
I'll test the reverse 'write' operation next ..
I expect this might be longer ..if at all possible ??
approx 120mb of data
Well to complete the test ..the results of the write time ..
the same data sent the other way took around 6 minutes ..but DID complete.
obviously only fat or fat32 supported
