aceb
- Oct 2, 2007
Prof Tuner 7301 /
- Sussex
Moonbase, I'm not using a 36V controller, it's a 12V PSU and is just wired via a switch that lets me free move the small actuator, slowly. To get it back on arc I just move to a non inclined sat and peak the signal. For the amount it gets used I wasn't going to fork out on another positioner. The actuator is one of these http://www.satshop.tv/Actuator-Jaeger-DARL-3610-
I doubt build quality has improved, when mine failed and I received the replacement it had the same issue of the two plates being out of align. I would also suggest that the motor needs another elevation bolt to spread the load. I fitted one using the bolts that hold the motor inside the casing. Since then I had to regularly check the screws inside as they work lose (I've since fitted star washers to prevent it happening). This really needs doing prior to install because once it's assembled the upper front half of the case is impossible to remove.
Positioning wise it's very good and I can't fault it, it also copes with the 1.2 well which is in a very exposed location but mechanically it's poor. The aluminium used in both the casing and the CM plate appears to be very low quality and I'm quite sure it will fail at some point even no matter how many bolts are holding it down. Would I buy another when this one fails, probably not but depends what else is available, the gibby PM doesn't look particularly robust and I think is limited in its coverage. Maybe look for a 1224?
