So changing from 12v Halogen to 12v LED (bollox ?)
Archive4
Surely ( not shirley ) the heat generated within the bulb is more from the pcb than the led´s? Cannot ever remember coming across a hot led. My dog´s collar had several led´s and ran off a 3v lithium battery, as do many " Christmas hats " and assorted paraphernalia sold at various times of year. No heat, just pretty lights. I also have about three types of led work lights that run on standard batteries or re-chargeable, never got hot yet.
Or am I using the wrong led´s?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well ..fwiw ..these high power high brighness leds do generate a fair amount of heat ..
If you don't believe me ...open up an LED TV screen/panel ..if you're brave enough ..
On larger TVs the actual LEDs are mounted on heatsinks not just pcbs ..
In the case of the led bulbs ..I doubt a single LED can generate enough heat to be an issue ...but 12 in close proximity ?
I've yet to check the heat generated ...it's on my to do list ..
Personally I don't believe it to be that excessive but heated air rises ..and will heat any air trapped in the confined space within the glass chamber ..this may result in thermal runaway..
is this chamber sufficiently evacuated even ..?
I simply dont have those answers..
does anyone here know for sure ?
certainly when I smashed that glass it did not pop like a conventional lightbulb.
rgds
VS
Archive4
If you don't believe me ...open up an LED TV screen/panel ..if you're brave enough .. ( yes I´m brave enough, just not stupid enough)
In the case of the led bulbs ..I doubt a single LED can generate enough heat to be an issue ...but 12 in close proximity ? ( gathering of the clan)
I've yet to check the heat generated ...it's on my to do list .. (get on with it)
Personally I don't believe it to be that excessive but heated air rises ( as we all know, we all fart ).and will heat any air trapped in the confined space within the glass chamber ..this may result in thermal runaway..( and the need for a chilled toilet roll )
is this chamber sufficiently evacuated even ..? ( I doubt it )
does anyone here know for sure ? ( only one I can think of )
certainly when I smashed that glass it did not pop like a conventional lightbulb. ( nah! more like microwave popcorn )
rgds
VS
2cvbloke
Near Pontop Pike, Co. Durham
Can't see it being lethal at 12v 1amp..but still..
Like I say, if it was using an capacitive dropper (versus an isolated transformer), which is referenced to mains, give it a path direct to earth, zappy times, I should know, I did just that recently, after I made this quick instagram vid actually:
@twocvbloke on Instagram: “Hand of god, or current leakage due to crappy household wiring? You decide... :P”
Suffice to say, I shall not be touching broken LED filament bulbs again, but I do need to investigate why the live and neutral is swapped in this house, cos that lamp was off, so must have been switching the neutral, not the live...
Archive4
We get that all the time in Spain, NEVER trust Spanish wiring, ALLWAYS turn the mains off.
2cvbloke
2cvbloke
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So here are some temperature readings take(n) from the exposed pcb it having run hanging just under the downlight fitting for about 16 hours non stop..
LED in centre cluster 29.7 c
LED in outer cluster 28.8 c
one of the 43 ohm resistors .. 30.2 c
the bridge rectifier .. 30.4c
the pcb around the point of resoldering .. 35.1 c
These are minimum values as holding onto the pcb whilst checking temeratures for more than a minute was actually painful ..
yes the pcb is that hot ..
and remember it is now air cooled having no glass envelope..
So ..the question remains does the pcb get hot enough in a closed space to partially liquify certain solders ?
I'm guessing yes ..
The unclothed LED lamp pcb is not showing any signs of failing after 16 hours straight running ..
rgds
VS
Archive4
So here are some temperature readings taked from the exposed pcb it having run hanging just under the downlight fitting for about 16 hours non stop..
These are minimum values as holding onto the pcb whilst checking temeratures for more than a minute was actually painful .. ( whimp )
yes the pcb is that hot .. ( as I suspected )
So ..the question remains does the pcb get hot enough in a closed space to partially liquify certain solders ? ( yes, as I suspected )
I'm guessing yes ..
rgds
VS
Enough said! ( and it should have been temperatures ) ( taken ) etc.
2cvbloke
Archive4
Sorry, totally off topic. Please chuck all unwanted and obviously unrelated posts on the scrap heap, or however it is correctly written!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well ...they took about 3 weeks to arrive ...and I would much prefer a warm white ....but hey ..
at about £2 each were the cheapest I could find ..
unbranded plain white box ..but I'm sure they are the same ones that are sold in the UK ..but in a nice coloured box at around £5 each..
All the way from HK ..
So far I'm impressed with the amount of light they give out ...and unpowered from a distance look like conventional filament BN22 clear candle lamps..
After the Chinese New Year ...I'll go in search of the same lamp in warm white..
and possibly a dimable version ..
here are a couple of pix..
Now to see how long they last...
rgds
Is that ceiling flammable? :oops:
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
