- Aug 10, 2008
- Romania
Digis@t said:How you found this, which blind scan receiver, TBS 6925 or?
Sorry for delay response.I used to find these feeds with HW TBS6925.I saw the signal on spectrum analyzer, then I checked with the player.I had signal but I can not lock it.It took a few days before I find this sr.Finding this low sr is done step by step and not found by blindscan.You have to repeated attempts until you can lock the signal.If HW tuner would be able to narrow a step of 0.1 MHz, it would be easier to lock signal when active transponders are so close,only a 1Mhz step!
Perhaps if the tuner would know to narrow band further ,then you might find low sr.with blindscan.But it is a performance that this tuner also lock low sr.!!!
