TBS Card 6983
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
maybe linux driver issues
cristan200
hotbird
usa
hello i need driver 1.0.0.4 card 6983
ho has driver 1.0.0.4 ?
please uploud driver for me and take it in here for me
bema
Kungsbacka
www.sm6muy.se
TV server: Linux Ubuntu 14.04 LTS
TvHeadend 4.1-1355
TBS6904 (Quad DVB-S/S2)
Dish: TD110, Inverto black ultra quattro
TBS6205 (Quad DVB-T/T2)
Ant: UHF 100 El Triax, dir N
Client: Kodi v14.2 etc
Sweden
Yes probably in some cases. I use it with tvheadend and the adapters crashes all the time. First one, then the second. No data to the application. Every time I need to reboot my PC...
assemblersat
100cm motorized dish
2 fixed 100cm dishes
TBS5925 ,TBS6983
germany
wiki_sat
Sky Star 2.8a right now and TBS 6983 coming soon ......
Iran
Ratchet
Falkirk
TM 5402(M2), TBS 6983, Sky+ HD, Stab USALS HH100, Faval 1M, Triax TD54, Hauppauge HD PVR
Falkirk
Just took delivery of a TBS6983. Looking good so far with regards to blind scanning and low symbol rates. Should I be able to lock the RAI multi-streams on 5W with this card ? Got all the latest Crazyscan stuff and although it does see these transponders it says 'No Locked' - see attached jpg . Tried using driver versions 1.0.0.4 and 1.0.0.6 but to no avail. Any advice would be appreciated.
You don't need other drivers, but only enter this code at the Root-16416, as in the example below.
Ratchet
Falkirk
Falkirk
Thanks for the pointer satesco, found the option in Crazyscan. Excuse my ignorance but what is the significance of this number, is it broadcaster specific ? What about the Mediaset multi-streams and the French streams on 12648 V, is it possible to lock these ?
In short I quote from Promax what does it mean this code:"Physical Layer Scrambling or PLS is used in DVB-S2 as a way to improve data integrity. A number called the "scrambling sequence index" is used by the modulator as a master key to generate the uplink signal. This same number must be known by the receiver so that demodulation is possible."
Here are the codes used on transponders(Mediaset Multi Streams and the French Streams)from 5.0 W:
11012 V : Root 16416 12585 H: Root 8 12669 H: Root 8
11179 V : Root 16416 12606 V: Root 8
11637 V : Root 16416 12627 H: Root 8
11676 H : Root 16416 12648 V: Gold 121212
Ratchet
Falkirk
Falkirk
Thanks again satesco these are all locking now. Looks like I have some reading up to do....
New Windows Driver Release ;)
TBS6983 windows driver for TBS6983 is upgraded to V1.0.0.7, which fixes the problem that switch tuner B goes wrong with Crazycat
http://www.tbsdtv.com/download/
Laser
Thinking about getting the TBS 6983. In very simple steps could someone please explain how you connect one up please?
... From the LNB cables coming into the house......Do you need a special LNB etc.?
Would very much appreciate your help..... Thank you
As the TBS 6983 has two tuners, you can connect two LNBs to the card. If you have more than one LNB on your dishes, just use a DiSEqC switch to the LNBs.
No special LNB needed, just bog-standard Universal types.
Laser
Hi Llew
So you connect the TBS 6983 into your PC. Then could you explain please. .. Thank you
Laser
Thank you v much
Laser
Mainly the multistream services.. But what else can you receive...?
Archive-8
I use it for Ku-Band H+V & L+R,
C-Band 3.4-4.2 H+V & L+R
Ka-Band 18.3-18.8 L+R, H+V
Ka-Band 19.0- 20.2 L+R, H+V
And it's used for the 4:2:2 feeds and data signals.
drusattv
C& KU BAND SATELLITES // 2M PRIME & 110CM OFFSET//VU+DUO2//XCRUISER 420 HD//
KA-BAND...COMMING SOON......
iran
