TBS Card 6983
drusattv
C& KU BAND SATELLITES // 2M PRIME & 110CM OFFSET//VU+DUO2//XCRUISER 420 HD//
KA-BAND...COMMING SOON......
iran
tempo
47.5N, 42.2E / Russia
CrazyScan 1.0.2.115
with windows 8.1 X64
error::
Do you know if it works with Ka band aswell?
Seems you haven't the last necessary DLL libraries. Download Reqlibs.rar and unpack it into CrazyScan directory. Sometimes new dlls required for new CrazyScan version.
tempo
dxn
Estoril - Portugal
Prime-focus 2,10m, 0,2 LNB Black Inverto, TBS6983 dvbcard, Octagon SF4008 4K,
Dreambox7020HD, NOS cable 200mb, Tivusat, TDTsat Spain, TDT Portugal.
Estoril - Portugal
Bought a week ago this wonderful piece of hightec TBS 7983 dbb card and i've testing mainly on multistream packages and all work fine except french multistream package in 5w on 12648v.
I get the channels but get a frozen picture screen that changes every few seconds to another frozen picture screen.
What could be the problem? do this channels need a special configuration?
Should be OK with the correct PLS code (Gold+121212).
dxn
Estoril - Portugal
Estoril - Portugal
I already inserted that code, and get the channels, but as i said only get frozen pictures,
I am also using dvddream same version as you. Maybe tthe codecs are the cause? What codecs you use to watch this channels?
I'm using LAV video/audio decoders throughout (MPEG2, H264).
dxn
Estoril - Portugal
Estoril - Portugal
also using lav filters but chanels are completly freezed. ;(
Do'nt know what elsecould be the cause.
If everything works fine why not these channels? :(
willy_poodle
Ferguson Ariva 252 Combo, Hama Lypsi 3D Twin LNB, Hama Lypsi Quadswitch LNB, Maximum DiSEqC 8/1, Golden Media 4X1 DiSEqC, TBS 6983, Technomate TM-80 S
Liverpool
I've received my 6983 from buydvb and there is no metal cover on the tuner chip.
Is it just mine or have they stopped soldering them on?
It is V20
dana.1365
Yama202
iran
The card knows symbol rate lower than shows technical specification-139 Ks. Found on Intelsat 902 at 62.0E in C-band.
Thank
LNB how to get this frequency model?
C-band LNB brands?
Dish size for 62-E How to?
I caught this transponder-4072 R with low symbol rate-139 Ks with an old lnb,MTI-Taiwan,from '90s and the antenna of 1.50m.
alireal
qbox
iran
hi i need driver 1.0.0.4 card 6983
ho has driver 1.0.0.4 ?
please uploud driver for me and take it in here for me please upload mediafire or uptobox
intracube
DM600
England
Linux user here
I've worked through a few issues and 'make' now compiles without any errors.
I'm concerned about running 'make install' as root. 'make --dry-run install' shows the script would end up removing/overwriting a large number of existing .ko files that are part of the base system.
PasteAll.org
- lines 87 to 93 as an example
(files are already on my system - provided by the kernel packages)
Why is it doing this?
I had hoped just a few modules/drivers would need to be installed o_O
Any help would be much appreciated.
pontiend
Contibruter
south yorkshire
I have had my TBS6983 card for 24 hours now.Progressing nicely.Tuners working alright.EBS Pro,Crazyscan.
Got stuck on EBScan though.It finds transponder. But not modulation,spectrum,or FEC, Bit Rate Zero.It save them in DVBDream Transponders .A scan in DVBDream though shows no transponders.Not surprising though .Settings seem to be fine.I am obviously missing something.Advice would be appreciated.:)
Jamie A
View attachment 85402 View attachment 85403
Have a read through this thread Pontiend mate. Llew mentioned this on page 2. Not sure if it was ever resolved.
pontiend
Contibruter
south yorkshire
Thanks Jamie The version that I am using is
4.3 stable (maintenance release) [21 Sep, 2012] .Which looks a little old.Maybe I need a different Version.
