TBS Card 6983
That's a very comprehensive list, thanks :D
I'll do some checking on those, at least those I can receive here.
dana.1365
Yama202
iran
Hi. Tbs6925 best or tbs6983.
I am frume iran.
dana.1365
Yama202
iran
Data fregunc 16Apsk test for tbs 6983.?
dana.1365
Yama202
iran
Tbs6983 tested whether receiving data in C-band frequencies؟
Put photos or videos of receipt
dana.1365 said:
Tbs6925 best or tbs6983.,
1.I don't know what it means the best when we talk of the two cards,TBS6925 or TBS6983. Both cards know to do the same thing:blindscan,16/32APSK, record stream,MIS,etc ,the only difference is that last can find symbol rate under 200 Msps and has dual tuners,sensitive to weak signal.For now, until CrazyCat will provide support for TBS6983 card, TBS6925 card is valid and it can be used "as if it" would be the best.But better read what I wrote in # 33.
2.Yes, TBS6983 Blindscan find both transponders in 16 and 32 APSK.
3.Also with this card you can scan in C-band.Here are some examples with TBS Blindscan and EBS Pro:
dana.1365
Yama202
iran
Thank you very much. What is the latest version tbs6925. I want the latest version tbs6925 flawless. I am in Iran. How can I get the latest version tbs 6925.
I want to satellite Internet. Which satellite and the maximum download speed is frequency? I thank my guide
1.If you want to know about the hardware version of TBS6925 card, read this thread at #748.The latest driver version is 1.0.1.23 and download it from here .
2.About the speed of the internet and the net provider I can not you recommend, because I don't know what speed he provide and that the satellite would be suitable for your area.It is true that there are satellites that transmit(only one way),files of all kinds (photo, video, youtube, etc) and you can download them using skygrabber software.It's sort of a passive net.For this you can use any Dvb-S2 card,not only TBS6925 or TBS6983.And looks like this:
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well it appears I do have 2 pcie slots so in theory can mount both my 6925 and the 6983 ...which arrived today.
I've done some slot juggling and got the 6983 in the PC ...but on boot it did not report new hardware found ..
I find that odd ..
Hope it's not a shared slot or somesuch..
Question..
Would the 6983 work with the 6925 drivers..or are they specific ?
Would Crazyscan recognise the card ..eben though it currently cannot use it..?
Is it acceptable to have both cards in the PC or would they conflict ?
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ok set a restore point ...
Always prudent.
Installed the TBS6983 driver from the supplied disc
Running up Crazyscan I see 3 options in hardware ..
The 6925 and 6983 tuner 1 and 6983 tuner 2
Selected tuner 1 ...I get RF scan not supported as has already been posted in this thread by Llew...
So ..which software can the card use ?
There is a version of TBS viewer on the disc ...
I am about to install this.
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So TBS viewer is a complete waste of space for me ..
No facility to select diseqc 1.1 switching that I can see ..
TBS blindscan ...the same ..
Cant get it to run with DVBviewer pro either ..
Sees the tuners ..but does sod all with 'em
Looks like it will just sit in the PC indefinately until some 'proper' software becomes available.
VS, I've got Two TBS cards in my PC, TBS 6220 (terrestrial), TBS 6983, and a TBS 5925 USB tuner. All drivers working fine.
The only application that I'm using with the TBS 6983 is EBSPro, as Crazyscan can't be used - yet.
With EBSPro, you can only use BlindScan 2, as the RF Spectrum option is defunct (like Crazyscan)
So the TBS 6983 is limited in what it can do, until programmers like CjCr and Crazycat can manage to break open the front end.
I'm in conversation with CjCr (EBSPro's originator) trying to get the Inverto LNB option in EBSPro to open up to other LNB LO's so we can use our SL3 LNB's (as Crazycat did for you). At present it's greyed out.
Oh, and you can also use TBS Blindscan of course.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well at least I've seen a picture produced by one of the tuners now ..
It will work with DVBviewer Pro ....with the correct tuner selected ...and the 6925 greyed out/disabled ..
,,and the other neccessity was a reboot after the drivers and TBS blindscan was installed.
TBS viewer is a pile of pants for my system as I can't control my diseqc 1.1 switch ..thus select the relevant lnb on any dish.
ie TBS viewer has no front end switch control other than basic 4 port diseqc switching.
Thanks for the info Llew..
You red devil you :D
Vipersan said:
...Would the 6983 work with the 6925 drivers..or are they specific ?
Is it acceptable to have both cards in the PC or would they conflict..
1.Both cards have their own driver,for TBS6925 is v.1.0.1.23 and for TBS6983 is v.1.0.0.4.On my OS under Windows 7 64bit,both drivers were installed without problems and works well.So there is no conflict between them.
2.@Llew reply to other your questions.
3. I must add that all dvb-s2 players(DVBViewer,ProgDVB,Dream DVB,AltDVB,SmartDVB ) works very well with TBT6983 cards.TBSViewer(as other TBS Dvb-S2 players)is a player with limited functions.
So it works well even with softwares that we have now, even partially with Crazyscan and EBS,for which we are waiting until the author will create a new software for TBS6983 card.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Looks like I shall have to get me a copy of EBS pro ..
I have the basic edition somewhere ...but 'tis a bit limited as I remember..
...anyhoo the Prof is on soon ...so c u in an hour guys
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ok ...installed the latest EBSpro (stable 11202) ...
switched to blindscan 2 ...
also sent my donation in Euro ...and am waiting for a password ..
Should this be sent immediately ?
only been waiting about 20 minutes so far ...but nada in my inbox
rgds
VS
Retired human
I got mine within 10 minutes but I believe it's a manual process, so no doubt you'll get it when he wakes up tomorrow :)
Looking at my past emails for EBSPro, I got a receipt on 13 Jan 2012 at 00:23, and the password arrived at 08:25 same day.
Might be first thing tomorrow?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Guess he must be having a lie in ..
still no password ...and EBS pro is all but useless till you can set your own ranges ..
Does he have a contact email Llew ..perhaps you could PM it to me
rgds
VS
