Hi
not sure if this is the right place to post this but here go's
i am running a windows 7 64 bit server with DVBlink server installed
a dvds/s2 card all this works fine with the FTA channels that are not encrypted
i have a TBS3102 5 Crystal Phoenix Card Reader and a TNTsat card,
the problem that i am haveing is that i can't get it to decrypted the encrypted channels
below is the log file if anyone could help it would be great
thanks
#START#
C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\ACamd.dll
13:20:52.717: ACamd v0.6.2.0
13:20:52.726: MD-API Version 01.06
13:20:52.729: systems: registering CA system Cardclient, pri -15, ident 1000
13:20:52.729: structloaders: registering loader cardclient config
13:20:52.729: cardclients: registering cardclient Newcamd
13:20:52.729: cardclients: registering cardclient Newcamd2
13:20:52.729: cardclients: registering cardclient CCcamN
13:20:52.729: cardclients: registering cardclient Radegast
13:20:52.729: cardclients: registering cardclient Camd35
13:20:52.729: structloaders: registering loader smartcard data
13:20:52.729: systems: registering CA system SC-Irdeto, pri -10, ident 1001
13:20:52.729: feature: using feature SMARTCARD
13:20:52.729: registering Irdeto smartcard (id 49726474)
13:20:52.729: systems: registering CA system SC-Seca, pri -10, ident 1002
13:20:52.729: registering Seca smartcard (id 53656361)
13:20:52.729: systems: registering CA system SC-Viaccess, pri -10, ident 1003
13:20:52.729: registering Viaccess smartcard (id 56696173)
13:20:52.729: systems: registering CA system SC-Conax, pri -10, ident 1004
13:20:52.729: registering Conax smartcard (id 436f6e78)
13:20:52.729: systems: registering CA system SC-Cryptoworks, pri -10, ident 1005
13:20:52.729: registering Cryptoworks smartcard (id 4372576f)
13:20:52.729: systems: registering CA system SC-Nagra, pri -10, ident 1006
13:20:52.729: registering Nagra smartcard (id 4e616772)
13:20:52.729: systems: registering CA system SC-NDS, pri -10, ident 1007
13:20:52.729: registering NDS smartcard (id 56694732)
13:20:52.731: Monitor listen on port 50965
13:20:52.764: B:Betatunnel, CAID:1833 with Provider:00000000 to CAID:1702 with Provider:00000000
13:20:52.764: Engine [MD-API]
13:20:52.764: loading smartcard data from C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\smartcard.conf
13:20:52.765: loaded 5 smartcard data from C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\smartcard.conf
13:20:52.765: loading cardclient config from C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-2\plugins\cardclient.conf
13:20:52.765: ** registered systems:
13:20:52.765: ** SC-NDS (pri -10)
13:20:52.765: ** SC-Nagra (pri -10)
13:20:52.765: ** SC-Cryptoworks (pri -10)
13:20:52.765: ** SC-Conax (pri -10)
13:20:52.765: ** SC-Viaccess (pri -10)
13:20:52.765: ** SC-Seca (pri -10)
13:20:52.765: ** SC-Irdeto (pri -10)
13:20:52.765: ** Cardclient (pri -15)
13:20:52.765: COM3: open serial port
13:20:52.785: COM3: set serial options: 9600,SM_8O1
13:20:52.787: smartcards: added serial port COM3 as port 0 (normal CD, normal RESET, CLOCK 3571200)
13:20:52.787: 0: new card inserted
13:20:52.787: COM3: set serial options: 9600,SM_8O1
13:20:52.789: 0: reseting card
13:20:52.790:
13:20:54.540: 0: indirect convention detected
13:20:54.540: 0: atr decoding TS=3f hist=7 Y1=70 TA1=18 F=372 D=0.000000 TB1=00 TC1=00 N=0 Y2=00
0: historical: d3 8a 42 01 64 90 00
0: historical: '..B.d..
Blocked 2 same messages...
13:20:54.540: 0: atr checksum not given/not required
13:20:54.540: 0: indicated wwt(T0)=1000 ms, bwt(T1)=1600 ms (at 3.5712 MHz)
13:20:54.540: 0: Init Viaccess card
13:20:54.540: ReadIni: COM3_9600 default 0 now set to 1
13:20:54.540: 0: read baudrate from menu, baudrate 0 to 9600
13:20:54.541: COM3: set serial options: 9600,SM_8O2
13:20:54.542: card v.unknown
13:20:54.913: card UA: 312649919
13:20:55.312: provider FFF400 (ISSUER)
13:20:55.696: provider 030B00 (TNTSAT)
13:20:55.729:
Blocked 1 same messages...
13:21:21.532: Ch: 100 - TF1
13:21:21.532: Programm crc: 255C4CF5
13:21:21.533: PMT: ACamd_PMT.txt, search, found...
13:21:21.533: PMT: Index=2 PMT=0064 SID=2329 CAID=0500
13:21:21.533: PMT: Provider=00030B00 ECM=0500 EMM=0100 Name=TF1
13:21:21.534: 0x0064 0x2329 0x0500 0x00030B00 0x0500 0x0100 11111110
13:21:21.778: Incomming PackageSize [184]
13:21:21.829: provider not found on card
13:21:21.829: SC-Viaccess 0: ECM [0500][0500/00030B00] Pro (0.000)
13:21:21.829: SC-Viaccess 0: ECM [0500][0500/00030B00] not able to decode
