uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
digi247
NW
see sig
kota said:
Thanks for that ..
Apologies it appears the Info i was told is wrong i have just been informed by another user with a TM6900 that it is still operational, the Info i was informed by a DrHD F15 user, I cannot check myself as my Motorised is out of action for the forseeable future due to a little mishap LOL
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
Yes I've also read reports on other forums they've encrypted the PMT and Linux E2 machines get confused about it. Somewhere up in this thread it's been said this might happen sooner or later ...
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
Can confirm the Technomate is still opening them
Cheers
digi247
NW
see sig
And another update the DR HD F15 is clearing these again today maybe someone with a Linux receiver could try just in case they work as well
kota
Sintra - Portugal
yes they do !! They're back ....
dxn
Estoril - Portugal
Prime-focus 2,10m, 0,2 LNB Black Inverto, TBS6983 dvbcard, Octagon SF4008 4K,
Dreambox7020HD, NOS cable 200mb, Tivusat, TDTsat Spain, TDT Portugal.
Estoril - Portugal
That means PMT isn't encypred for the moment. Linux boxes only open them when this happens.
Фрэнк
Motorised 1m 30W-28.2E and Static 1.3m 28.2E
Skyway Diamond, Protek 9760HDIP, Ferguson Ariva 100E
Vinuela, Spain
Hi new to the forum, I just wanted to know if anybody has any EPG information with BBC-SATBACK as I don't. Any help welcome.
Hixxy1
East Midlands
Hi and welcome to the forum. Unfortunately these channels don't carry EPG info.
Фрэнк
Vinuela, Spain
Thanks for the quick answer, I suppose I was hoping for to much from these channels.
I'm pushing my luck now, another question, can you or anybody recommend any other decoders to handle BBC-SATBACK the main criteria's are 'cheap' and 'reliable'.
Hixxy1
East Midlands
If you plan to watch these channels fairly often, I've been told that the Technomate 5402 or Dr HD receivers are the ones to go for. One of the reasons is these channels periodically encrypt the PMT which stops pretty much all receivers from opening the channels. Whereas these two specific receivers can handle the PMT.
Just remember if & when illicit reception of these channels goes mainstream the Beeb will almost certainly encrypt them properly & everyone will lose them.
BLUEPLATINUM
Maspalomas, Gran Canaria
Well I have just acquired a Technomate 5402 HD M2 and am trying to pull this in using a 1m dish but I cannot even find the bird. I keep finding Hispasat at 30W. I am sure I have read reports from the Canaries that the BBC package is being received a on a 1m dish. Can anyone confirm please. BTW - the LNB is an Inverto Black Ultra . Thanks.
digi247
NW
see sig
Looks like your right on the edge of the footprint for reception
cheekymonkey
In the sunshine
3 smallish dishes andaccess to 1 very big one.(7w, 13e,19e, 28.2e, 27.5w)
TM 5402hd,dm500s,vu+solo, pc,laptop,tablet,smartphone. Smartmeter S1 (since someone robbed my satcatcher excel tv mk4)) emitor micro HD. very old promax explorer
Canary Islands
1.2 metre definately in East of canaries. 1.1 not yet tried but may be marginal.
Currently using 1.35 tecatel (1.35x1.25) and getting near enough 80% quality showing on tm5402.
trigger
A 1M should just about do it. I get It here on a 1.1 that's on a motor. What are you using to try and find it? Once you have found Hispasat then adjust your skew as best as poss then its left a bit & up a bit and you should find it - hopefully
BLUEPLATINUM
Looks like my dish may be marginal, but I do have a good LNB.
I have a basic sat finder with a needle gauge and tone which changes pitch with signal strength. I have printed information off from dishpointer; according to them the parameters are very similar::
HISPASAT INTELSAT 907
Elevation 53.9 Elevation 55.0
Skew 25.2 Skew 21.4
and only 2.5 degrees difference in the azimuth.
I have never aligned a dish before and with these very small differences I am not sure how to proceed.
As you've found Hispasat, optimise reception on that, then adjust towards 27.5W by nudging tiny amounts in Azimuth only - the Elevation difference shouldn't be too critical at this stage. When you are satisfied that you have got the correct Azimuth, lock it off. Only then pay attention to raising the Elevation slightly. Finally, twiddle with skew (If really necessary)
ie Don't try to engage in three-dimensional adjustment - do it one step at a time, majoring on Azimuth.
jacko
tenerife
<sub>hello am in tenerife and was using a 1 metre dish ,black ultra lnb and tm 5402.</sub>
<sub>now using 1.2 metre dish.first of all i found hispasat with a sat metre,then selected</sub>
<sub>advanced search on the tm box for 27.5 west ,select the transponder and watch the signal bars</sub>
<sub>on advanced search.i marked the pole and dish first on hispasat and flexed the dish up,</sub>
<sub>and the signal came in for the bbc package.the line on the dish and pole for hispasat are still in line,</sub>
<sub>so must be very close.hope this helps.</sub>
BLUEPLATINUM
So just to clarify
1/Lock on Hispasat using meter.
2/Display BBC t/p on Technomate (will show <10% quality and high signal (false) but both in red.
3/Tweak ELEVATION watching Technomate display optimising quality
Is that right.
BTW why did you change the dish?
Thanks for the help.
jacko
tenerife
<sub>yes thats correct blue platinum.</sub>
<sub>the 1 metre dish i had would lock onto the signal 95 percent of the time.</sub>
<sub>the 1.2 metre dish 100 percent.</sub>
