VU+ Duo Twin Tuner
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
compufunk said:
In short, its comparable to a DM8000 but costs half the price.
The hardware is very similar to that of the DM8000, so similar that you can run an image designed for the DM8000 on it (Not recommended though). The main difference in hardware is that it has two fixed tuners as opposed to the DM8000's potential 4 interchangeable ones.
The three main teams developing images for it (AFAIK)are Pli, VTI and Dream-Elite.
One of the big benefits as opposed to other Linux receivers on the market is that it uses a processor with the same architecture as the E2 Dreamboxs. This means that you can run anything compiled for Dreambox on the VU+, including the popular CCcam.
''as opposed to the DM8000's potential 4 interchangeable ones.''
2 interchangeable ones....as the two onboard DVB-S2 Tuners (A & B ) are fixed on the Mother Board, not Plugable.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
still you can always add tuners thru USB..i have TDT and Cable tuners (USB stick) and work great
father ted
just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve
scotland
Mickha said:
Depends on the motor, I'm using a 1224 which has dedicated wires connected to the motor, probably in your case you use the coax cable, which should probably be connected to Tuner A, on the VU+ Duo.
One wire goes from the LNB to the motor then to your receiver, tuner A, the second goes from the second LNB output to Tuner B.
What motor do you have?
hi its the same as this one ... http://www.satellites.co.uk/forums/...s/39396-moteck-sg-2100-manual.html#post199734 see where it has 2 screw threads?at this moment i have one from the lnb to one side and the other comes from the back of the box to what am assuming is the drive part of motor, so am i right in saying it would
as i have it now 1 cable from 1st lnb to the first screw part (as i have it now)
1st part of twin coax from tuner 1 to the drive part of motor
2nd part of tuner to another lnb
i cant get duo lnb's here
Mickha
North West
As it shows in the pictures, picture 2, but make sure that the cable from the motor goes to Tuner A, as this is the one that drives the motor, the second just runs as normal from the LNB to Tuner B.
Hakon
My setup
Laminas180cm P.M 60e-30w
24" SuperJack,Clark-Tech V-Box
Laminas120cm CM P.M 75e-30w
18" Superjack, Clark-Tech V-Box
Gibertini XP premium 100cm
Polar Mount, 12" Superjack
75e-30w
2 x Vu+ Duo
Sweden south
That's not correct as i can run my DiSEqC rotor connected to tuner B.
I have 2 DiSEqC rotor and later i will test if its possible to run 2 rotors to the Vu+ Duo
I also like to show all what type of fan theres in the Vu+ Duo, have read in some forums that it's a 7v fan and thats not correct its a standard 12v PC fan. I have not checked the voltage on the MB where the fan connects but i can think theres 7v. This gives a lower speed on the 12v fan.If you Google the fan you will find the data .
cormachogan
Dreambox DM800, Vu+ Duo in the way, Triax TDA88 dish, Geotrac SG2100 motor,Inverto Twin Black Ultra LNB
Dublin
Just ordered a Vu+ Duo to replace my Dreambox 800HD. Hopefully it'll be here by Friday so I can play with it over the weekend.
Thanks to all who have contributed to this thread! :-beer
Taihape
optus D1
NZ
I'm having real problems transferring/copying files over to an ext hdd or even a usb stick! One hdd it doesn't recognise at all. What is the procedure because the instruction book is a waste of time?
compufunk said:
I havent tested in a while, but I managed to simultaneously record 5 HD channels when I first got the reciever. That was the max only because the tuners were working to capacity. The resulting recordings were glitch free.
You can use a 3.5" SATA HDD internally, or an external drive (USB or eSATA). Transferring recordings to PC is no probelm via FTP or using external USB storage.
sonnetpete
wordpress.com
Normandy, France
I think that the hard drives have to be formatted to FAT32. Maybe that's why it won't recognise your HDD.
profixit
TM1000D+
Vu+ Duo
Panansonic TX L42D25B
4 Ps3's Two slim and two phat (original 60gig version)
London
Then there would be a 4GB file size limit?
