VU+ Duo Twin Tuner
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
i just found this topic,are the also some clones out of the VU+ Duo Receiver,and how i can check it that is a clone or not?
how good is the tuner on weak signals?
hm sat dont response to my mails,means i will not order on this shop!
where the vu+ company is located in korea also?
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
Turok said:
Hello!
Vu+ duo is made by MARUSYS in Korea the same maker of the Kathrein UFS910
Telia
Vu+ Duo PVR 1GB HDD
Channel Master 1.2m with Jaeger SMR1224.
Stockholm, Sweden
Here is my review
I received it today and at first it was loaded with the default image and the picture quality was decent not more, i knew it could deliver better with new image drivers and so on i loaded the latest DreamElite image and i must say the picture quality is excellent now.
Adjusting the Autoresolution settings to 576i for SD and 1080i for HD interlaced and 720p for HD progressive and turning off both options at the end for de-interlacing the image is much much better than my original DM800HD i had.
This is one really neat receiver, it's fast, great quality, nothing to complain about, it's the best receiver i ever owned and i wasted so much money on bad boxes like IPBOX9000, Azbox etc......
So thumbs up for great build quality.
I tested the tuner sensitivity as it's very important for me as i receive Astra2D with my Channel Master 120cm in Sweden, the tuner is much better than the one in my previous original DM800HD box i had and it's actually comparable to the old IPBOX9000HD with Sharp tuner i had, this time of day i get lots of pixelations with my original Sky HD DSI8215 receiver on the vertical transponders on Astra2D, but with Vu+ i have no pixelations at all so it's much better for sure, the DM800HD i had showed lots of pixelations as well.
So thumbs up for Vu+ Duo tuner sensitivity.
What i like also is the black remote control, the remote is much better feeling with the buttons than Dreambox own remotes, short stiffened feel of the buttons and the upgrade with USB is really great.
So thumbs up for the remote control and the excellent flashing options compared to Dreambox.
What more can you ask for? it's the best receiver on the market right now.
wod
yorkshire
what's good about this receiver ? i've heard loads are raving about this one. I'm after a hd receiver and been keeping an eye on this. are these better than dreamboxes then in terms of hardware and software ?
was going for the azbox but unsure now
pipino
Back from the dead
please dont !!! you will comit the worst satellite crime ever ...LOL ...i never saw such shit box in my life...realy big advice dont buy it
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
In short, its comparable to a DM8000 but costs half the price.
The hardware is very similar to that of the DM8000, so similar that you can run an image designed for the DM8000 on it (Not recommended though). The main difference in hardware is that it has two fixed tuners as opposed to the DM8000's potential 4 interchangeable ones.
The three main teams developing images for it (AFAIK)are Pli, VTI and Dream-Elite.
One of the big benefits as opposed to other Linux receivers on the market is that it uses a processor with the same architecture as the E2 Dreamboxs. This means that you can run anything compiled for Dreambox on the VU+, including the popular CCcam.
CROSSBONES
S.Wales
The VU+ Is in a "proper" size case, no over heating like some of the 800`s, like mine did. The shelf where I used to keep the 800 on has a slight bow from the heat!!
It also has 2 CI and 2 card slots. Updating the images is also easy, via a USB stick.
And at £400 its a bargain, get one wod you wont be disapointed.
wod
yorkshire
I'm tempted i only wanted azbox for the 4:2:2 thing anyway, I've kept out of linux boxes after stupidly getting one of them technomate ones which was awful.
should go nicely on my 1.2m i've just got.
pipino
Back from the dead
4.2.2 is the reason to buy AZcrap ??,,for 4.2.2 pci sat card will do for those rare transmissiones anyway
wod
yorkshire
just seen some videos on youtube of this receiver and it is looking tempting.
the hd to hd channel change is rather fast.
whats the verdict on picture quality of sd channel ? i will be using a sub card in it for football matches.
installing images is it best by usb stick ?
Telia
Vu+ Duo PVR 1GB HDD
Stockholm, Sweden
Well, it's the fastest performing Enigma2 receiver to date as the drivers are really slick.
One of the advantages of the Vu+ compared to other Linux receivers is that you can flash the image really fast by just putting the image on a USB stick, then you turn off the receiver, put the USB stick in the front, turn the power on and it will flash automatically, no other receiver can do it this good.
Picture quality is very good, at least as good as the Cuberevo which is considered to be the reference in picture quality.
wod
yorkshire
another thing i'm wondering about is recording what is that like ?
is the hard disc internal and can you copy recorded things over to the pc ?
pipino
Back from the dead
it does all what DM8000 do exept integrating the DVD burner
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
I havent tested in a while, but I managed to simultaneously record 5 HD channels when I first got the reciever. That was the max only because the tuners were working to capacity. The resulting recordings were glitch free.
You can use a 3.5" SATA HDD internally, or an external drive (USB or eSATA). Transferring recordings to PC is no probelm via FTP or using external USB storage.
scadden
Sky Dish with Sky+ and two old digiboxes
2 PC's & 2 Laptops
Ireland
I just ordered mine from satellitetv dot ie for €399. It a good bit cheaper than any place else.
Should be with me on Tuesday. I'll be all set for glorious HD for the World Cup.
I'm used of using Enigma 1 so is there many advantages of Emigma 2?
totalacedude
Edit. 5620 several 500,'s (clones) vu duo blackhole pc server 95cms motorised dish blah blahh
crewe
wod.
installing images from usb is childs play! plug it in boot it and its done!
receiver is gr8, sd quality is better than my old 800 and hd is.. well i cant fault it! id say above average!
only gripe is sometimes zapping is slow, but im using a big image with lots going on! ie my pagefile is in constant use! (memory wise)
nice and big so stays cool.
no real narks... ian
father ted
just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve
scotland
ok this seems very newbie but can someone explain how i set up quad lnb on motorised dish for the vu+duo?
do i buy twin cable and how?where does it go?
Mickha
North West
As it's a duo receiver, 2 tuners, you only need a dual LNB, then you can either run 2 separate cables, from the 2 outputs on the LNB to the 2 tuners, or use shotgun cable, which is 2 cables combined together, whichever best suits your needs for installation.
father ted
scotland
surely i need a cable from a lnb to motor? so that would make it 2 from 2 lnbs and a third for the motor?
Mickha
North West
Depends on the motor, I'm using a 1224 which has dedicated wires connected to the motor, probably in your case you use the coax cable, which should probably be connected to Tuner A, on the VU+ Duo.
One wire goes from the LNB to the motor then to your receiver, tuner A, the second goes from the second LNB output to Tuner B.
What motor do you have?
