Amos 7 (was Asiasat 8) 4W
100cm
11542 H 3700 10.9 dB TVH :)
12315 H 15000 5.5 dB No lock
for me 12315 H 15000 0 db no lock with 3,7m
VodzigorLans
Setup is down atm
RU, Saint Petersburg
11652 H 3333 biss feed is active again... signal is ok
Tippmix is now at 11567 H 15000
2017-03-02 16_16_00-SmartDVB _ TBS 6903 DVBS_S2 Tuner 0 [bda.dev]  [ID_0].jpg
adonis1
adonis1
after a blind scan few minutes ago on 4° West I'm getting:
10721H 12.6 db
10757V 14.1
10757H 13.9
108O5H 12.8
10841H 13.1
10888V 15.2
10906H 14.0
10971V 9.6
11138H 12.8
11175H 14.2
11221H 6.1
11257V 15.7
11257H 14.3
11302H 15.5
11314H 15.1
11340V 15.7
11394H 10.8
11424H 16.4 the strongest signal
11455H 5.7
11473V 10.2
11541H 12.4
11556V 9.6
11567V 13.2
11625V 6.8
11929V 9.9
11646V 7.4
11658V 14.4
12314H 14.3
Only got my 80cm up at the moment, but TVH on 11542 H 3700 is coming in nicely, much to my surprise!
Earlier this morning
11567 H 15000 = 7.1dB
11652 H 3333 = 7.3dB
TM5402HD M3 + 100cm===TM6902HD
Amos @ 4 west = 10am==6:30pm
10722 H 27500 = 7.3===62%
10722 V 30000 = 9.2===63%
10758 H 30000 = 8.3===64%
10758 V 30000 = 9.3===64%
10806 H 30000 = 5.5===64%
10806 V 30000 = 9.1===60%
10842 V 30000 = 9.2===61%
10842 H 30000 = 9.1===63%
10889 V 30000 = 10.1==66%
10907 H 15000 = 6.9===64%
10925 V 30000 = 9.9===64%
11140 H 30000 = 0
11176 H 30000 = 4.5===0
11425 H 30000 = 0
11542 H 3700 = 0====56%
11610 H 3600 = 0
12315 H 15000 = 0
Amos-2
Latitude @ 10am was 0.54
Latitude @ 6:30pm is 0.14 still coming on the arc
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I'm getting 11315H at 14.0 db !!! with dish 1.5m
I am receiving that signal (14db) down here with my 1.2 Dish. See my thread nr.31
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
12543H 3700 TVH is not aligned with other, older Amos channels. It's peak signal is almost a degree east and reaches peak when ABS3a Hellessat test card can be viewed. Made the mistake of using TVH to lock onto 4.0w...Does not work! I think it is 1\2 a degree out of alignment.
100cm + TM5402HD-M3==TM6902HD=TM5502HD==M3
Amos @ 4 west = 10am==6:30pm===7:45pm====8:0pm
10722 H 27500 = 7.3===62%======68%====9.3dB=67%
10722 V 30000 = 9.2===63%======63%====8.6===61
10758 H 30000 = 8.3===64%======68%====8.8===62
10758 V 30000 = 9.3===64%======67%====8.7===61
10806 H 30000 = 5.5===64%======66%====8.8===62
10806 V 30000 = 9.1===60%======61%====8.2===58
10842 V 30000 = 9.2===61%======64%====8.5===61
10842 H 30000 = 9.1===63%======72%====9.0===63
10889 V 30000 = 10.1==66%======72%====9.3===66
10907 H 15000 = 6.9===64%======80%====9.7===70
10925 V 30000 = 9.9===64%======68%====9.0===63
11140 H 30000 = 0======0=======0======0=====0
11176 H 30000 = 4.5====0========0=====3.9===27
11425 H 30000 = 0======0=======0=======0====0
11542 H 3700 = 0====56%=======56%====9.1===65
11568 H 15000 = 0=====0========69%====9.5===68
11610 H 3600 = 0=====0========0 ======0=====0
Zik has now moved to Amos-7 CEE Beam no signals here
12315 H 15000 = 0=====0========0=======0=====0
Amos-2
Latitude @ 10:00am was 0.54
Latitude @ 6:30pm was 0.14 still coming on the arc
Latitude @ 7:45pm was 0.00
Latitude @ 8:15pm was 0.07 when this list was completed.
2nd March 2017
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Correction 11543H not 12543H
Laser
H William-1 Good Evening,
Am I right in thinking reading your chart throughout the day a lot of the European services are still on Amos 2 ? Or has everything from Amos 2 gone now to 7?
Its difficult to tell as the SQ on some transponders hasn't varied much where as on others it has.
Difficult to know!
Amos 2 is still operational @ 4 west despite the rhetoric to the contrary of it switching off 2 days ago I think we are looking at a phased change over for a few more days.
MCelliotG
Thessaloniki, Greece
Amos 2 is definitely still in operation, and none of these three birds are in the very same orbit either. This makes it almost impossible to get a perfect alignment, thankfully I'm inside the Euro/Eastern beam so it doesn't matter that much, but still there are huge differences between frequencies.
11585 H,2604,5/6-Slovakia feed
Indeed with the latest three successive TLE's, it seems Amos 7 is maintained at 3.85°W, not at 4.0°W like Amos 2 and 3.
0.15 degrees is definitely enough to see the difference on the 1.8m... Anyone getting Middle Eastern anywhere in Europe?
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
