2.4 DH Antenna installation
This is why the wife's Sky stuff and my everything-else stuff is separate!
I had the same issue with my many remotes where pressing OK on my Dune's remote control box (since retired) would switch HDMI switch to another input... Grr..
blademedia
Sky
I guess it could be annoying, luckily the controller is in a temporary location and eventually it will be controlled by laptop.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
hello ,
just found the exact same CHAPARRAL COROTOR unit please could you confirm the KU band frequency range on this??? i couldn´t find any datasheet or papers with it
cheers
The User concerned ceased to be a Member here three years ago ..........
pipino
Back from the dead
well.. what a shame !!
pipino
Back from the dead
i found this
The Corotor II Plus Wideband is for receptions of circular and linear C-Band signals in the 3.4-4.2GHz range and linear Ku-Band signals in the 10.95-12.75GHz
since we are now lower from 10.70GHZ , i was wondring if this hardware will cover it the whole 10.70-12.75GHZ
Yes, it will receive the lower band frequencies (Astra 1d).
I used a Cal Amp wide band LNB on one up until about three years ago.
pipino
Back from the dead
Thank you for the swift reply mate
