- Jul 2, 2005
- Location
- Epping Forest
- Epping Forest Essex
use file live_prog for channels & satellites list , lamedb only for view in editor.
I don,t understand this. Can somebody explain this or where can i find the file live_prog.
When you save your channel list in backup & recovery you will see a new menu:-
Settings export to USB
Settings import to USB
Import settings from network
Dump firmware
Select export to USB then tick what you want to save from this list:-
DVB channel list
System settings
Stalker
IPTV
Biss keys
CAM settings
OSCAM
WEBTV
Select DVB channel list to USB stick,
When you want to reload via USB stick in Backup & recovery
select import settings from USB stick:
You will see USB Disk1:/dev/sda1
Selecting this option opens the file to reveal several options:
Select SX88+_2018_10_22_1.04.72_0.dbase (This is the name of the file that I have saved today) & press OK,
This file contains the file live_prog 324KB this is the DVB channel list.
