C-Band Extended
65W pure carrier on 4602 H, maybe something new , soon...
.... nothing showing here at the moment (9am-UK) for that frequency, just the usual three carriers, will keep obs :Y
frankviana
Satellites/tv
Brazil
Blindscan tests Vu+ Zero 4k. Transponders found, but no channels. I see channels using manual scan only after replace tp lists (satellites.xml).
Satellites.xml (blindscan)
.. Firing the machinery up right now - will report back asap :Y
It's here with me as well, looks very similar in size to the 4768 V signal.
Anonymous_1
Yes, smae parameters , maybe a copy, let's hope to have a lock one day..
@John , thanks for your report
2 news
@65°W 4770 V mux has left
Good news the mux on 4650 V has a better SNR now (copy of 4770V)
cheers
Only just managed to get dish back up onto C-band this morning due to high winds all of last week - this is a good signal with me and locks easily now :Y
... the 4650 V signal has been gone for a couple of days now but iv'e been watching the area around 4770 V with what seems to be two signals side by side. Possibly needs a bigger dish to make anything out of it - take it away fellas.
Only one mux, the mux 45 msps same as before
Thanks for that Feedsat, - the uncertainty was fueled here when you look at the two plots taken with some time difference of a few days of that particular frequency span.
@ 65° West again.
Football - 4614 H.
65W 4770 in H ??
no SR found yet
Managed to get a very quick lock at around 6.8dB but didn't stay locked long enough to get some data off it. Has been up to 8dB but the promax won't catch it.
At 65° West - - Can anybody check this out with a bigger reflector - - 4588 H.
Shifting polarity to Vertical see's the trace go flat.
