Just Sharing This Multifeed 28°e - 33°e - 39°e - 45°e
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Skewed dish Triax TD 110, from left to right:
twin 45°East FTA
quad 39°East FTA
quad 33°East Multistream FTA
single 28°East FTA
Feel free to copy the idea in UK.
I'm a fan of fast sweeching betwin 15 satellites ( from 6 dishes ) and I use 3 DiSEqC 16/1 for 3 TVs in my house.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Nicely made! :)
I guess aligning the dish (finding your central satellite) is a bit of a hassle, skewed like this? Have you got a trick for that?
Or did you manage to set the skew-axis plate perpendicular to boresight (satellite direction), as is usually the case with multifeed dishes, if I understand correctly?
Greetz,
A33
Ah another fan of fast switching - I cba to wait for a motorised system to switch between far east & far west hence the weird & wonderful sysytems Ive rigged over the years in the 2 locations Ive lived.
LeBelge
Belguim
Nicely made! :)
Previously, this dish was in the same place. 51,5°E - 45°E - 39°E
Seeing how big the inclination of the three LNB is, for the new dish I decided to skew it.
First I found the central satellite, then I skewed the dish. Before the LNB for 39°E was in the center, because the bulgarian multistream was on it. When the MIS moved to 33°E, I changed the cables from 39 to 33 and from 45 to 39 and I turned the dish to have 33 in the center. So, now the skew of the dish is not exactly like it should be, but it works. Anyway the skew of the converters is set for maximum performance.
LeBelge
Belguim
maxi_power
120cm motorised dishes
PT
You're right, but remains limited to x satélites.
LeBelge
Belguim
You can connect 32 satellites to 4K sat receiver with twin DVB-S2X tuner and 2 DiSEqC 16/1.
Every 50" TV has at least 2 HDMI inputs, so, 2 receivers x 32 = 64 satellites.
maxi_power
PT
It takes a big garden...:)
126506
RimaNTSS
Some SAT-related hardware.
N-E from Riga
If you go "multi-focus antenna way" than using 2-3 of them is possible to cover whole arc.
maxi_power
PT
It's a good idea, despite the costs.
RimaNTSS
N-E from Riga
despite the costs.
Firstly, if you buy second hand T90s, looking for bargain, of course, than expenses can be minimized to reasonable amount. And, secondly, who cares if we speak about hobby! :D
a33
XSAT410
Rebox RE-9000
The Netherlands
If you combine diseqc 1.1 with diseqc 1.0 ('position' and 'option' command), you can switch 16 x 4 = 64 LNBs.
Some 8/1 switches (and maybe also 16/1 switches? I've no experience with those) can also switch on diseqc 1.2 commands.
Combine that with diseqc 1.0 and 1.1, and you can switch 512 LNBs (or even 1024, with a 16/1 switch?).
Of course, if your receiver supports a 0/12V switch, you can again double that amount. But, alas, in that case a 0/12 volt cable should be added somewhere; so that would not be via just one cable (the antenna cable).
Limited to hundreds of satellites...?
To me that is fine... (I have just 4 fixed LNBs plus 1 at the motor, at the moment....) :)
Greetz,
A33
LeBelge
Belguim
... And, secondly, who cares if we speak about hobby! :D
It depends on each person's motivation.
Some people are interested in sports and pay a professional to install a dish with a motor and watch feeds like that ( FTA or BISS). Others want to watch paid bouquets of 2 -3 satellites and are happy with just one DiSEqC 1.0. There are some that are only interested in the latest receiver model and 2 meter antennas for the C band.
The only motivation that I had in 1999 when I bought my first analogue receiver, was simply to watch the only Bulgarian satellite channel (here in Belgium).
Now in 2019 my motivation is not to pay for TV subscriptions and watch channels from different countries. I am interested in the different cultures across Europe. I passively understand several European languages, but I also watch channels from Greece, Hungary or Brazil without understanding their languages.
For me, spending money on dishess, receivers, converters, DiSEqC, cables etc is O.K.
But for me, it would be a humiliation to pay 50 euros a month for a subscription from Sky or Chanal+ ( the french one). The pay TV business model is not my cup of tea. Television content is better when it's free.
I also find that it is better not to depend on the Internet for watching TV.
I do not want my internet provider to know what time which channel I watched.
LeBelge
Belguim
How will it work on Enigma 2 ?
p.s.
3 dB + 3 dB = 6 dB
maxi_power
PT
Greetz,
A33
Now i have 1 fixed and 1 with diseqc motor.
a33
XSAT410
Rebox RE-9000
The Netherlands
When you can set both the diseqc 1.1 command, and the diseqc 1.0 command, in your receiver menu: just fine.
All normal modern receivers can manage that, I guess.
Just not all TV-tuners, and 'closed boxes' from providers, and maybe cheap receivers, I would guess.
greetz,
A33
LeBelge
Belguim
I guess that it will work that way:
but for the moment I don't need more thаn 16 satellites.
Thanks for the suggestion.
There was a US college trying to palm off a toroid antenna a few weeks back before it was cut up for scrap.
A few small modifications and some oars and one could get it across the Atlantic.
