daro2096
- Jan 21, 2009
- Age
- 49
- No setup at present
- Consett, Durham
I would have used wideband LNBs such as the Inverto ones with unicable multiswitches. That way you would have only ran 8 cables from dish to multi switches. Well that is how I would have done it anyway.
There is a German shop on eBay that sells a Inverto Unicable multi switch and two wideband LNBs for about £137.50 including post to UK. You would need to buy 2 for 4 satellites and you can run it on up to 32 receivers/tuners. Much cheaper than 4 quarttos and a 17in 16out multi switch.
