Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
I am sure I saw a CAID on older Roscrypt channels (non T2 MI)...
The issue with that is that receivers would not know that the channel is encrypted and would not try to send the stream to the CAM. Though that's probably not the biggest problem. The biggest one is that Roscrypt CAM does not like most consumer receivers. Openbox one is the only one I know of that recognises it. Anyway, going off topic... Carry on.
MCelliotG
Thessaloniki, Greece
Yes, RosCrypt had a caid A101. Ghostcrypt does not! Most probably they feed the DVB-T2 transmitters with a special cardless receiver that decrypts the stream before terrestrial broadcast. I think they abandoned Roscrypt as it is now fully compromised.
Sutarman
Yamal 601 @ 49°E
Indonesia
Where is the problem, when trying to stream analysis it always fails.
Message :
[core/socket 4] getaddrinfo () failed
Name or service not known
Sutarman
Yamal 601 @ 49°E
Indonesia
duck77
Sorry, just clarification.
Why the Data ServiceRef that I can differ from the data you have.
For frequencies 3704 and 4018, on the Yamal 601 satellite.
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
duck77
Maybe because i put flag on P (Use PIDs).
The way I have it works on my vu +.
EnoSat
enosat.euweb.cz
Slovakia
some EMM data on main stream
MCelliotG
Can you explain what does the above mean? I don't see a specific reference to Perviy channel, just the whole stream.
EnoSat
enosat.euweb.cz
Slovakia
know-how about update Gostcrypt CAM ?
Sutarman
Yamal 601 @ 49°E
Indonesia
Thanks for all
Succeeded in SF4008
It doesn't/won't work in Enigma2 - it doesn't even initialise in it.
I just put the CAM in Openbox and it gives me colours.
EnoSat
enosat.euweb.cz
Slovakia
send CAM with Stream to Octagon support ;)
4Himdj
1.2 Laminas Dish
Rome
hello I hope you can help me because support of my new e2 receiver seems disappear (From the beginning)
i have ax hd 61
please let me know what do I write in lamedb to watch 54,9 east. yes I know I should read first post but I did not understand. I've copied what mgcelliot post about bouquet and astra.conf but I don't know what to write in lamedb
this is a very important test for me because I suspect this receiver have some kind of problem (don't know what and nobody seems able to help me) with astra-sm, in fact also on hispasat I've problem and I can see nothing.
I suspect this because when I select a channel viewable through stream relay, the tuner is not occupied and i can normally switch to other satellite channels.
thank you very much
ps no problem on octagon sx88+ as you can see here
best regards
i have ax hd 61
The general rules of the forum are that you have to make the effort yourself. You cant expect someone else to do the work for you Go through all the posts from the beginning again. With a bit of luck you will understand and get it working.
If you arent willing to put the effort in then you have to do without.
nirvana
disk 150
italy
I just made a new config for 54.9E, working great!
Here's my new config in astra.conf
-- RTRS 54.9E
f12674rtrs0 = make_t2mi_decap({
        name = "12674V T2-MI  PLP0",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B182:0:0:0:", -- required
        plp = 0,
        pnr = 0,
        pid = 4096,
f12674rtrs1 = make_t2mi_decap({
        name = "12674V T2-MI  PLP1",
        plp = 1,
        pnr = 0,
        pid = 4096,
f12694rtrs0 = make_t2mi_decap({
        name = "12694V T2-MI  PLP0",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B196:0:0:0:", -- required
        plp = 0,
        pnr = 0,
        pid = 4096,
f12694rtrs1 = make_t2mi_decap({
        name = "12694V T2-MI  PLP1",
        plp = 1,
        pnr = 0,
        pid = 4096,
make_channel({
        name = "12674rtrs0 ", input = { "t2mi://f12674rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/12674plp0", },
make_channel({
        name = "12674rtrs1 ", input = { "t2mi://f12674rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/12674plp1", },
make_channel({
        name = "12694rtrs0 ", input = { "t2mi://f12694rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/12694plp0", },
make_channel({
        name = "12694rtrs1 ", input = { "t2mi://f12694rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/12694plp1", },
and the bouquet content
#NAME RTRS T2-MI (54.9E)
#SERVICE 1:64:16:0:0:0:0:0:0:0::---------- RTRS T2-MI (55E) ----------
#DESCRIPTION ---------- RTRN T2-MI (55E) ----------
#SERVICE 1:0:1:3F2:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:01 ПЕРВЫЙ КАНАЛ
#DESCRIPTION 01 ПЕРВЫЙ КАНАЛ
#SERVICE 1:0:1:3FC:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:02 РОССИЯ-1
#DESCRIPTION 02 РОССИЯ-1
#SERVICE 1:0:1:406:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:03 МАТЧ!
#DESCRIPTION 03 МАТЧ!
#SERVICE 1:0:1:410:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:04 НТВ
#DESCRIPTION 04 НТВ
#SERVICE 1:0:1:41A:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:05 ПЯТЫЙ КАНАЛ
#DESCRIPTION 05 ПЯТЫЙ КАНАЛ
#SERVICE 1:0:1:424:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:06 РОССИЯ-К
#DESCRIPTION 06 РОССИЯ-К
#SERVICE 1:0:1:42E:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:07 РОССИЯ-24
#DESCRIPTION 07 РОССИЯ-24
#SERVICE 1:0:1:438:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:08 КАРУСЕЛЬ
#DESCRIPTION 08 КАРУСЕЛЬ
#SERVICE 1:0:1:442:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:09 ОТР
#DESCRIPTION 09 ОТР
#SERVICE 1:0:1:44C:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:10 ТВ Центр
#DESCRIPTION 10 ТВ Центр
#SERVICE 1:0:1:7DA:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:11 РЕН ТВ
#DESCRIPTION 11 РЕН ТВ
#SERVICE 1:0:1:7E4:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:12 Спас
#DESCRIPTION 12 Спас
#SERVICE 1:0:1:7EE:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:13 СТС
#DESCRIPTION 13 СТС
#SERVICE 1:0:1:7F8:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:14 Домашний
#DESCRIPTION 14 Домашний
#SERVICE 1:0:1:802:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:15 ТВ3
#DESCRIPTION 15 ТВ3
#SERVICE 1:0:1:80C:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:16 Пятница
#DESCRIPTION 16 Пятница
#SERVICE 1:0:1:816:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:17 Звезда
#DESCRIPTION 17 Звезда
#SERVICE 1:0:1:820:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:18 МИР
#DESCRIPTION 18 МИР
#SERVICE 1:0:1:82A:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:19 ТНТ
#DESCRIPTION 19 ТНТ
#SERVICE 1:0:1:834:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:20 МУЗ ТВ
#DESCRIPTION 20 МУЗ ТВ
#SERVICE 1:0:2:456:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:ВЕСТИ ФМ
#DESCRIPTION ВЕСТИ ФМ
#SERVICE 1:0:2:460:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:МАЯК
#DESCRIPTION МАЯК
#SERVICE 1:0:2:46A:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:Радио России
#DESCRIPTION Радио России
hello, sorry but then you can't also post how the lamedb file should be configured?
All the info you need has been posted on the forum. YOU have to put the work in to get things working. You will get general guidance only.
nirvana
disk 150
italy
I have not found any information on the topic as it is necessary to edit the lamedb
