- Oct 12, 2003
- See Signature
- Somewhere in England (possibly?)!
Just finished (well, I thought I had!) configuring a "newish" Win 10 Pro 64 bit HP Z230 "Tower" (4th gen iCore 7 cpu, 16GB of RAM, SSD, etc.) and fitted the DVBSky S952 that came out of the old EliteDesk - only to find that that card appears to now be totally dead (not even showing up in Device Manager).![Sad :( :(](https://www.satellites.co.uk/styles/default/xenforo/smilies/sad.png)
Therefore, as one reason for getting the Z230 was make more use of that card, then it looks like I need to get "something else" to replace it - and preferably something that can handle stuff like Crazyscan, and so, in conjunction with the "extra power" under the hood from the processor.
I'm sure that some of you guys who have used the TBS, etc., cards will have some suggestions, and so I'd be grateful to hear them - BTW a dual tuner card would be nice but a decent single tuner one would probaby be OK (and a bit cheaper).
Thanks in advance.
Thanks in advance.
