TP appearing over a 10 degree search
namracyor
8 Satellite receivers, Echostar AD 3600 IP solely used as the dish mover. Technamate TM 6900 Combo, Amiko Alien 2 Spark Triplex, Edision Piccollo s2-T2/C, Technomate TM 8000 Combo, Amiko-X-Finder 2, Octagon SF 8008 +4K, ab Cryptobox 752HD. 1.2 metre Channel Master dish with a twin Invert Tech .2db LNB. 2 computer set up consisting of 2 HP Desktops. Multiple switching units and HDMI splitters.
Near Dorking
I am getting a strong signal at 10746 H 32000 Auto on this satellite yet both Lyngsat and FlySat register the lowest frequency for this satellite at 10950.
The nearest possible satellite that is registered as starting at 10700 is KazSat 3 at 58.5 East.
The TP appears active over a 10 degree search.
Any ideas?
namracyor
Near Dorking
Sorry should have stated a start point, about 65 East to beyond 58 East.
It could be a spurious output from the equipment, but low elevation suggests breakthrough at the IF stage , terrestrial source into the incoming cable, or f-plug
What LNB you are using ?
namracyor
Near Dorking
Inverto Black Tech 0.2db. Channel Master 1.2 Dish. Receiver ab CryptoBox 752HD.
namracyor
Near Dorking
I live near a railway, and a mobile phone mast. The Amiko-X-Finder spectrum analyser registers the signal but doesn't download to the data base. On the ab CryptoBox it is showing as a data feed because I am getting two channels at the same frequency, the second reads 10746 H 3200/Auto/M:0 .
Assuming the LNB is working correctly you should be looking for a signal of around 994-998MHz , 996MHz is a common frequency for circuitry within multiswitches (and from memory) some commercial UHF repeaters.
namracyor
Near Dorking
A Friend has just checked with Intelsat. 62 East is operating at 10750. FlySat registers a TP @ 10808. I am now on my way to Specsavers!
Save a few quid, open another bottle and check again in the morning.
